[mapserver-users] NoData Gap between rasters - Tileindex Layer
Bartlomiej Burkot pomiarowiec10 at poczta.onet.pl
Fri Aug 29 03:16:54 PDT 2014
Dear MS Users
I have a set of rasters which I warped to epsg:3857 projection using
gdalwarp.
During the reprojecting the new raster had been rotated by small angle.
After that I created a tileindex shape file using gdaltindex and
configured layer:
LAYER
         NAME "myname"
         TILEINDEX "tilindex.shp"
         TYPE RASTER
         OFFSITE 0 0 0
     END
On the result map I see the gaps between raster files. Please look at
images:
http://mmapa.pl/gaps_between_rasters.PNG
http://mmapa.pl/two_separate_files.PNG
http://mmapa.pl/mapserver_layer_as_tileindex.PNG
Maybe some of you recognize the problem. There is the problem with one
pixel gap between raster files in tileindex layer.
Maybe there is a option in gdalwarp command to extend the new image by
making it 1 pixel widther? Maybe something like resampling method or
algorithm?
I googled similar problem in goeserver:
https://www.mail-archive.com/geoserver-users@lists.sourceforge.net/msg06220.html
Could you please point me to the right solution?
Thanks in advance
Bartek
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140829/94470537/attachment.html>
