[mapserver-users] XML parsing error with extended Inspire WMS 1.1.1 capabilities
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Feb 6 08:14:32 PST 2014
Hello,
Thanks, we will try to do a pull request on this soon.
Y.
2014-01-31 Eichner, Andreas - SID-NLKM <Andreas.Eichner at sid.sachsen.de>:
> > I get this error: Namespace prefix xsi for type on MandatoryKeyword
> > is not defined
> You're right. The problem using DTD is that namespace declarations are done
> using FIXED attributes. Therefore the DTD part
> <!ATTLIST inspire_common:MandatoryKeyword
> xmlns:inspire_common CDATA #FIXED "
> http://inspire.ec.europa.eu/schemas/common/1.0"
> Should be:
> xmlns:xsi CDATA #FIXED "http://www.w3.org/2001/XMLSchemainstance"
> Because for element inspire_common:Keyword the xsi:type attribute is
> declared
> it should probably also be done for the inspire_common:MandatoryKeyword.
> So I would consider this being an incomplete document type definition.
> Fixing this should be simple.
> HTH
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140206/39ee4114/attachment.html>
