[mapserver-users] XML parsing error with extended Inspire WMS 1.1.1 capabilities
Yves Jacolin
yves.jacolin at camptocamp.com
Fri Feb 7 03:30:07 PST 2014
FYI, Pierre Mauduit worked on this:
https://github.com/mapserver/mapserver/pull/4861
Y.
2014-02-06 Yves Jacolin <yves.jacolin at camptocamp.com>:
> Hello,
> Thanks, we will try to do a pull request on this soon.
> Y.
> 2014-01-31 Eichner, Andreas - SID-NLKM <Andreas.Eichner at sid.sachsen.de>:
>> > I get this error: Namespace prefix xsi for type on MandatoryKeyword
>> > is not defined
>> You're right. The problem using DTD is that namespace declarations are
>> done
>> using FIXED attributes. Therefore the DTD part
>> <!ATTLIST inspire_common:MandatoryKeyword
>> xmlns:inspire_common CDATA #FIXED "
>> http://inspire.ec.europa.eu/schemas/common/1.0"
>> Should be:
>> xmlns:xsi CDATA #FIXED "http://www.w3.org/2001/XMLSchemainstance"
>> Because for element inspire_common:Keyword the xsi:type attribute is
>> declared
>> it should probably also be done for the inspire_common:MandatoryKeyword.
>> So I would consider this being an incomplete document type definition.
>> Fixing this should be simple.
>> HTH
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 021 619 10 43
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140207/124699cf/attachment.html>
