[mapserver-users] MapServer should not collapse geometries in same layer class
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Feb 7 08:58:07 PST 2014
On 2/7/2014 10:48 AM, Gregor Karzelek wrote:
> Hi,
>> If the aim is to see objects end, isn't GEOMTRANSFORM END just perfect
>> for that?
> In theory GEOMTRANSFORM „end“ seems perfect for this. But according to
> my tests the GEOMTRANSFORMED style is painted below the other styles. No
> matter on which position in the STYLE list of the CLASS I put it (Or is
> there some Z-Order feature for STYLE I haven’t seen yet?). So it just is
> not what we would need, as we would need those marks on top of
> everything else.
> So I an issue at Github as suggested (I hope it contains everything
> necessary).
The STYLEs are rendered in the order they are encountered in the mapfile.
So if you want it on top then make it the last style block.
-Steve W
