[mapserver-users] Σχετ: Mapserver can't read mapfile
Stefanos Anastasiou
emperor_stef at yahoo.gr
Mon Feb 10 07:49:45 PST 2014
Sorry fellows... indeed there is a typo but in this e-mail... I checked my files again and they seem correct...
If I type on my browser: http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop.map&mode=map all I get is a blank page. The data folder has full permissions: drwxrwxrwx
All other shapefiles are working correctly but yesterday I just added two more in the folder and all I get is a blank screen... (?)
Στις 5:37 μ.μ. Δευτέρα, 10 Φεβρουαρίου 2014, ο/η Jörg Thomsen <jt at mapmedia.de> έγραψε:
please have a look at your path:
and
> http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop/map
I guess the first one is correct and that's why you get the error-msg
with the 2nd one. So, what exactly is the result of the request
http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop.map&mode=map ?
it sounds like a white image, not nothing. In this case you should check
the bboxes and srs first.
regards, Jörg
Am 10.02.2014 16:15, schrieb Stefanos Anastasiou:
> Hello!!
> I'am having my mapfile place in /home/mapdata folder whereas I also keep
> a couple of other mapfiles too.
> I'm trying to load it in the following form on the
> and all I get is a blank page. No errors no nothing.
> Then I created an html template in order to click it from there by
> creating a simple link (and not a from) in the following hyperlink: <a
> href="http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop/map&mode=map>
> This link </a>
> And I get the following error: msLoadMap(): Unable to access file.
> Last time this happened I was invoking Mapserver through a form but this
> time it's just a simple link.
> Why is it happening ?
> The weird thing is that all the other mapfiles that are seem to be
> working are are having the same permission settings with the
> current: -rw-r--r--
> Thanks a lot!
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140210/72e3e6ad/attachment-0001.html>
