[mapserver-users] Σχετ: Mapserver can't read mapfile
Fawcett, David (MNIT) David.Fawcett at state.mn.us
Mon Feb 10 08:00:19 PST 2014
To further diagnose this, it would be useful to see the contents of you mapfile.  If no errors are being thrown, it is quite possible that there is an issue with spatial reference systems, bounding boxes, or class expressions.
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stefanos Anastasiou
Sent: Monday, February 10, 2014 9:50 AM
To: jt at mapmedia.de; mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Σχετ: Mapserver can't read mapfile
Sorry fellows...  indeed there is a typo but in this e-mail... I checked my files again and they seem correct...
If I type on my browser:  http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop.map&mode=map   all I get is a blank page. The data folder has full permissions:  drwxrwxrwx
All other shapefiles are working correctly but yesterday I just added two more in the folder and all I get is a blank screen...     (?)
Στις 5:37 μ.μ. Δευτέρα, 10 Φεβρουαρίου 2014, ο/η Jörg Thomsen <jt at mapmedia.de<mailto:jt at mapmedia.de>> έγραψε:
please have a look at your path:
and
> http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop/map
I guess the first one is correct and that's why you get the error-msg
with the 2nd one. So, what exactly is the result of the request
http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop.map&mode=map ?
it sounds like a white image, not nothing. In this case you should check
the bboxes and srs first.
regards, Jörg
Am 10.02.2014 16:15, schrieb Stefanos Anastasiou:
> Hello!!
> I'am having my mapfile place in /home/mapdata folder whereas I also keep
> a couple of other mapfiles too.
> I'm trying to load it in the following form on the
> and all I get is a blank page. No errors no nothing.
> Then I created an html template in order to click it from there by
> creating a simple link (and not a from) in the following hyperlink:  <a
> href="http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop/map&mode=map>
> This link </a>
> And I get the following error: msLoadMap(): Unable to access file.
> Last time this happened I was invoking Mapserver through a form but this
> time it's just a simple link.
> Why is it happening ?
> The weird thing is that all the other mapfiles that are seem to be
> working are are having the same permission settings with the
> current: -rw-r--r--
> Thanks a lot!
> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140210/63edb641/attachment.html>
