[mapserver-users] Σχετ: Mapserver can't read mapfile
Jörg Thomsen jt at mapmedia.de
Mon Feb 10 08:09:41 PST 2014
once again: I have never seen a blank screen when calling mapserver.
I bet there is a withe image try a right-click in your browser-window.
What exactly did you do? Only copying shp-files into the data-folder?
changing the map-file that worked before? creating a new mapfile?
Jörg
Am 10.02.2014 16:49, schrieb Stefanos Anastasiou:
> Sorry fellows...  indeed there is a typo but in this e-mail... I checked
> my files again and they seem correct...
> If I type on my browser:
>  http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop.map&mode=map
>  all I get is a blank page. The data folder has full permissions:
>  drwxrwxrwx
> All other shapefiles are working correctly but yesterday I just added
> two more in the folder and all I get is a blank screen...     (?)
> Στις 5:37 μ.μ. Δευτέρα, 10 Φεβρουαρίου 2014, ο/η Jörg Thomsen
> <jt at mapmedia.de> έγραψε:
> Hi,
> please have a look at your path:
> and
>> http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop/map
> I guess the first one is correct and that's why you get the error-msg
> with the 2nd one. So, what exactly is the result of the request
> <http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop.map&mode=map>?
> it sounds like a white image, not nothing. In this case you should check
> the bboxes and srs first.
> regards, Jörg
> Am 10.02.2014 16:15, schrieb Stefanos Anastasiou:
>> Hello!!
>> I'am having my mapfile place in /home/mapdata folder whereas I also keep
>> a couple of other mapfiles too.
>> I'm trying to load it in the following form on the
>> browser:
>> and all I get is a blank page. No errors no nothing.
>> Then I created an html template in order to click it from there by
>> creating a simple link (and not a from) in the following hyperlink:  <a
> href="http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop/map&mode=map>
>> This link </a>
>> And I get the following error: msLoadMap(): Unable to access file.
>> Last time this happened I was invoking Mapserver through a form but this
>> time it's just a simple link.
>> Why is it happening ?
>> The weird thing is that all the other mapfiles that are seem to be
>> working are are having the same permission settings with the
>> current: -rw-r--r--
>> Thanks a lot!
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
