[mapserver-users] Serving tiled image sets with MapServer?
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Wed Feb 12 16:50:28 PST 2014
Ok,
I got this working, but right now it is really just a kludge. I have an
aspx/php script that serves up the tiles, and the GDAL minidriver
configuration file. I had to use the GDAL WorldWind minidriver due to the
way my tiles were layed out, with the 0 row tiles at the bottom, but since I
couldn't figure out how to set the <T> option I had to hard code it into the
URL. Anyway I now have it serving up my pre-tiled BMNG tile set to my WMS
client. Sweet! In case it helps anyone else, I'll post my aspx scritp,
and the gdal configuration file below. Any suggestion on how to set that
<T> option to be filled in by the minidriver would be greatly appreciated.
Thanks,
James
Tile.aspx --- Copy to the \ms4w\apache\htdocs directory
// This scipt is for serving out your own WW Cached tiles to World Wind,
useful for own imagery and for working "off line"
// This script can be named what ever you want, it is controlled via a World
Wind XML
// thanks to MaurizoZA and Nowak for the script
$X = $_GET['X'];
$Y = $_GET['Y'];
$L = $_GET['L'];
$T = $_GET["T1"];
function addzeros($string)
//echo $string;
if(strlen($string) >= 4)
return $string;
$string = "0" . "$string";
if(strlen($string) < 4)
$string = addzeros($string);
return $string;
$ext = ".jpg";
// Change the following to the location of your local root cache folder
$url = 'd:/MapData/TiledMapData/';
$doneurl = $url . $T . "/" . $L . "/" . addzeros($Y) . "/" . addzeros($Y) .
"_" . addzeros($X) . $ext;
$tileData = file_exists($doneurl) ? file_get_contents($doneurl) :
false;
if ($tileData === false) die();
@header('Content-type: image/jpeg');
print($tileData);
BMNG_01.2004.xml -- Copy to \ms4w\apache\cgi-bin
<GDAL_WMS>
<Service name="WorldWind">
<Version>1</Version>
<interface>worldwind</interface>
<ServerUrl>http://localhost/tile.aspx?T1=BMNG_01.2004</ServerUrl>
<Dataset>BMNG_01.2004</Dataset>
</Service>
<DataWindow>
<UpperLeftx>-180.0</UpperLeftx>
<UpperLefty>90.0</UpperLefty>
<LowerRightx>180.0</LowerRightx>
<LowerRighty>-90.0</LowerRighty>
<SizeX>81920</SizeX>
<SizeY>40960</SizeY>
<TileLevel>4</TileLevel>
</DataWindow>>
<Projection>EPSG:4326</Projection>
<BlockSizeX>512</BlockSizeX>
<BlockSizeY>512</BlockSizeY>
<BandsCount>3</BandsCount>
</GDAL_WMS>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140213/74e68d76/attachment.bin>
