[mapserver-users] Serving tiled image sets with MapServer?
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Tue Feb 11 14:59:46 PST 2014
That really helps. I've tried it, and I must be missing part of GDAL.
Gdalinfo returns info about my xml file, but when I try to access that xml
file from my mapfile layer, I don't get an image. In the access log there
is a bunch of errors that say "PHP Warning: PHP Startup: unable to load
dynamic library" and says that php_pqsql.dll could not be found. I've
searched and that file doesn't exist. So was this just left out of this
version of MS4W? Is there some way to add that capability into this build?
Thanks,
James
-----Original Message-----
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen at mmmtike.fi]
Sent: Monday, February 10, 2014 10:54 PM
To: EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE;
'mapserver-users at lists.osgeo.org'
Subject: Re: [mapserver-users] Serving tiled image sets with MapServer?
First step is to follow the GDAL WMS driver page examples and write a XML
configuration file for your tile service. Let's call it my_service.xml. You
can test if the file is correct with GDAL utility programs. If "gdalinfo
my_service.xml" is listing info about your service and "gdal_translate -of
GTiff -srcwin 0 0 1000 1000" my_service.xml test_out.tif" writes out a small
image you are ready to use your service with Mapserver. After that you
should be ready to use your tile data with Mapserver as LAYER
NAME "Layer from tiles"
DATA "my_service.xml"
TYPE RASTER
STATUS ON
-Jukka Rahkonen-
James_in_Utah wrote:
> Hi Jukka,
> Thanks for the reply. I just had a chance to look it over tonight. I
> followed the link to the gdal site, and it does indicate that the
> GDAL_WMS driver can access a WorldWind style tile server, which we do
> have. Beyond that, I'm not following your suggestion. Does the
> snippet you provided go in my Mapfile? I'm not familiar with that. I
> am running MapCache, but it doesn't really look like a grid or source
definition. Where would I use that snippet?
> http://osgeo-org.1560.x6.nabble.com/Serving-
> tiled-image-sets-with-MapServer-tp5102393p5103088.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140211/b9fb9ed6/attachment.bin>
