[mapserver-users] Serving tiled image sets with MapServer?
Rahkonen Jukka (Tike) jukka.rahkonen at mmmtike.fi
Mon Feb 10 21:54:19 PST 2014
First step is to follow the GDAL WMS driver page examples and write a XML configuration file for your tile service. Let's call it my_service.xml. You can test if the file is correct with GDAL utility programs. If "gdalinfo my_service.xml" is listing info about your service and "gdal_translate -of GTiff -srcwin 0 0 1000 1000" my_service.xml test_out.tif" writes out a small image you are ready to use your service with Mapserver. After that you should be ready to use your tile data with Mapserver as
LAYER
  NAME "Layer from tiles"
  DATA "my_service.xml"
  TYPE RASTER
  STATUS ON
-Jukka Rahkonen-
James_in_Utah wrote:
> Hi Jukka,
> Thanks for the reply.  I just had a chance to look it over tonight.  I followed the
> link to the gdal site, and it does indicate that the GDAL_WMS driver can access a
> WorldWind style tile server, which we do have.  Beyond that, I'm not following
> your suggestion.  Does the snippet you provided go in my Mapfile?  I'm not
> familiar with that.  I am running MapCache, but it doesn't really look like a grid
> or source definition.  Where would I use that snippet?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Serving-
> tiled-image-sets-with-MapServer-tp5102393p5103088.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
