[mapserver-users] Mapserver can't read mapfile
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Feb 10 08:46:41 PST 2014
Hi sorry long thread and I bet this has already been said, but here were
my thoughts when I read your problems:
- always test your mapfile at the commandline first, using the shp2img
utility (http://mapserver.org/utilities/shp2img.html). Once your layers
look find there in the generated map image then move to your application
- if using MapServer CGI (mode=map), a blank map often means you are not
specifically telling MapServer to turn on layers; try adding &LAYERS=all
- or setting each of your layer's STATUS values to DEFAULT might work
(but this can cause lots of trouble later, so this is not often recommended)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2/10/2014, 11:15 AM, Stefanos Anastasiou wrote:
> Hello!!
> I'am having my mapfile place in /home/mapdata folder whereas I also keep
> a couple of other mapfiles too.
> I'm trying to load it in the following form on the
> browser: http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop.map&mode=map
> and all I get is a blank page. No errors no nothing.
> Then I created an html template in order to click it from there by
> creating a simple link (and not a from) in the following hyperlink: <a
> href="http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop/map&mode=map>
> This link </a>
> And I get the following error: msLoadMap(): Unable to access file.
> Last time this happened I was invoking Mapserver through a form but this
> time it's just a simple link.
> Why is it happening ?
> The weird thing is that all the other mapfiles that are seem to be
> working are are having the same permission settings with the
> current: -rw-r--r--
> Thanks a lot!
