[mapserver-users] php mapscript setFilter and signal Segmentation fault (11)
Vladimir fl_v at inbox.ru
Fri Feb 14 02:33:13 PST 2014
 Hello dear developers.
Please could you give some direction for decision segfault problem. I tried  execute php-script only without mapfile:
$map=ms_newMapObjFromString("MAP NAME    \"WMSRoadrs\"  STATUS ON    CONFIG    \"PROJ_LIB\" \"/usr/lib/proj/\"    END");
$map->setMetaData("wms_title","Roadrs");
$map->setMetaData("wms_onlineresource"," http://localhost/msscript.php ");
$map->setMetaData("wms_srs","EPSG:3857");
$map->setMetaData("wms_enable_request","*");
$map->setMetaData("wms_encoding","utf-8");
and result of  first call $map->setMetaData  is "ignal Segmentation fault (11)" immediately as in my post above
Configuration: openSuse 13.1 Mapserver 6.4.1 php 5.4.3
Many Thanks.
Четверг, 13 февраля 2014, 15:08 +04:00 от Vladimir <fl_v at inbox.ru>:
>Hello All. Please help me to understand what's wrong.
>php mapscript version 6.4.1
>request url:
>localhost/script.php?LAYERS=roads&SRS=EPSG%3A3857&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=image%2Fpng&BBOX=8562963.8568664,5347815.0968664,8567741.1711336,5352592.4111336&WIDTH=500&HEIGHT=500
>works in mapfile.map:
>FILTER (id  in (386,400))
>but
>does not work in script.php:
>$roadsLayer->setFilter("id  in (386,400)");
>at that no other errors except the string in apache log:
>[Thu Feb 13 16:03:33.931054 2014] [core:notice] [pid 716] AH00052: child pid 2626 exit signal Segmentation fault (11)
>mapfile.map:
>MAP
>    NAME    "WMSRoadrs"
>    CONFIG    "PROJ_LIB" "/usr/lib/proj/"
>    STATUS        ON
>    WEB
>        METADATA
>            wms_title    "Roadrs"
>            wms_abstract    "Roadrs"
>            wms_onlineresource    " http://localhost/msscr/script.php "
>            wms_srs    "EPSG:3857"
>            wms_enable_request        "*"
>            wms_encoding    "utf-8"
>        END # end METADATA
>    END # end WEB
>    PROJECTION
>        "init=epsg:3857"
>    END # end PROJECTION
>    LAYER
>        NAME    "roads"
>        STATUS        ON
>        CONNECTIONTYPE    postgis
>        CONNECTION    "user=user password=1 dbname=db host=localhost"
>        DATA    "coor from tab using unique id using srid=3857"
>       FILTER (id  in (386,400))#-----------works
>        TYPE    LINE
>        CLASS
>            NAME    "дороги"
>                STYLE
>                    COLOR    255 255 255
>                    WIDTH    10
>                    OUTLINECOLOR    0 0 255
>                    OUTLINEWIDTH    1
>                END # end STYLE
>        END # end CLASS
>        PROJECTION
>            "init=epsg:3857"
>        METADATA
>            wms_title    "Demo1"
>            wms_abstract    "Roads Demo1"
>            wms_srs    "EPSG:3857"
>            wms_include_items    "all"
>        END # end METADATA
>    END # end LAYER
>END # end MAP
>script.php:
>ini_set('display_errors', E_ALL);
>error_reporting(E_ALL);
>$request = ms_newOwsrequestObj();
>if(!empty($_GET)){
>    foreach ($_GET as $key => $value) {
>        $request->setparameter($key, $value);
>ms_ioinstallstdouttobuffer();
>$map = ms_newMapobj("mapfile.map");
>$roadsLayer = $map->getLayerByName("roads");
>$roadsLayer->setFilter("id  in (386,400)");//-----------does not work
>$map->owsDispatch($request);
>$contenttype = ms_iostripstdoutbuffercontenttype();
>header('Content-type:'.$contenttype);
>ms_iogetStdoutBufferBytes();
>ms_ioresethandlers();
>Thanks _______________________________________________
>mapserver-users mailing list
>mapserver-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
Владимир
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140214/ada28f38/attachment.html>
