[mapserver-users] RESOLVED php mapscript setFilter and signal Segmentation fault (11)
Vladimir
fl_v at inbox.ru
Mon Feb 17 22:58:38 PST 2014
Hello All.
Apparently the mix of distros caused the segfault error.
I installed Mapscript from openSuse repository instead
Mapserver from official site.
Пятница, 14 февраля 2014, 14:33 +04:00 от Vladimir <fl_v at inbox.ru>:
>Hello dear developers.
>Please could you give some direction for decision segfault problem. I tried execute php-script only without mapfile:
>$map=ms_newMapObjFromString("MAP NAME \"WMSRoadrs\" STATUS ON CONFIG \"PROJ_LIB\" \"/usr/lib/proj/\" END");
>$map->setMetaData("wms_title","Roadrs");
>$map->setMetaData("wms_onlineresource"," http://localhost/msscript.php ");
>$map->setMetaData("wms_srs","EPSG:3857");
>$map->setMetaData("wms_enable_request","*");
>$map->setMetaData("wms_encoding","utf-8");
>and result of first call $map->setMetaData is "ignal Segmentation fault (11)" immediately as in my post above
>Configuration: openSuse 13.1 Mapserver 6.4.1 php 5.4.3
>Many Thanks.
>Четверг, 13 февраля 2014, 15:08 +04:00 от Vladimir <fl_v at inbox.ru>:
>>Hello All. Please help me to understand what's wrong.
>>php mapscript version 6.4.1
>>request url:
>>localhost/script.php?LAYERS=roads&SRS=EPSG%3A3857&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=image%2Fpng&BBOX=8562963.8568664,5347815.0968664,8567741.1711336,5352592.4111336&WIDTH=500&HEIGHT=500
>>works in mapfile.map:
>>FILTER (id in (386,400))
>>but
>>does not work in script.php:
>>$roadsLayer->setFilter("id in (386,400)");
>>at that no other errors except the string in apache log:
>>[Thu Feb 13 16:03:33.931054 2014] [core:notice] [pid 716] AH00052: child pid 2626 exit signal Segmentation fault (11)
>>mapfile.map:
>>MAP
>> NAME "WMSRoadrs"
>> CONFIG "PROJ_LIB" "/usr/lib/proj/"
>> STATUS ON
>> WEB
>> METADATA
>> wms_title "Roadrs"
>> wms_abstract "Roadrs"
>> wms_onlineresource " http://localhost/msscr/script.php "
>> wms_srs "EPSG:3857"
>> wms_enable_request "*"
>> wms_encoding "utf-8"
>> END # end METADATA
>> END # end WEB
>> PROJECTION
>> "init=epsg:3857"
>> END # end PROJECTION
>> LAYER
>> NAME "roads"
>> STATUS ON
>> CONNECTIONTYPE postgis
>> CONNECTION "user=user password=1 dbname=db host=localhost"
>> DATA "coor from tab using unique id using srid=3857"
>> FILTER (id in (386,400))#-----------works
>> TYPE LINE
>> CLASS
>> NAME "дороги"
>> STYLE
>> COLOR 255 255 255
>> WIDTH 10
>> OUTLINECOLOR 0 0 255
>> OUTLINEWIDTH 1
>> END # end STYLE
>> END # end CLASS
>> PROJECTION
>> "init=epsg:3857"
>> METADATA
>> wms_title "Demo1"
>> wms_abstract "Roads Demo1"
>> wms_srs "EPSG:3857"
>> wms_include_items "all"
>> END # end METADATA
>> END # end LAYER
>>END # end MAP
>>script.php:
>>ini_set('display_errors', E_ALL);
>>error_reporting(E_ALL);
>>$request = ms_newOwsrequestObj();
>>if(!empty($_GET)){
>> foreach ($_GET as $key => $value) {
>> $request->setparameter($key, $value);
>>ms_ioinstallstdouttobuffer();
>>$map = ms_newMapobj("mapfile.map");
>>$roadsLayer = $map->getLayerByName("roads");
>>$roadsLayer->setFilter("id in (386,400)");//-----------does not work
>>$map->owsDispatch($request);
>>$contenttype = ms_iostripstdoutbuffercontenttype();
>>header('Content-type:'.$contenttype);
>>ms_iogetStdoutBufferBytes();
>>ms_ioresethandlers();
>>Thanks _______________________________________________
>>mapserver-users mailing list
>>mapserver-users at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/mapserver-users
>Владимир
Владимир
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140218/f1075166/attachment.html>
