[mapserver-users] Upgrading Apache and PHP that came with MS4W
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Thu Feb 27 21:28:16 PST 2014
Thanks for the reply. That's too bad. I really won't have a choice very shortly. The apache 2.2.21 is showing up as a cat-1 vulnerability and We either get it upgraded or take it off. The same for PHP.
Thanks,
James
______________________________________
From: Rahkonen Jukka (Tike) [jukka.rahkonen at mmmtike.fi]
Sent: Thursday, February 27, 2014 2:26 AM
To: EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE; mapserver-users at lists.osgeo.org
Subject: Re: Upgrading Apache and PHP that came with MS4W
Hi James,
Nobody answered for you so supposedly that means that the answer is: No, there are no documents and probably no compiled Mapcache binaries available for Windows.
I managed to install Apache and Mapserver 6.4.1 from with the OSGeo4W installer. Also daily development buids of Mapserver are available but not Mapcache. The installed Apache seems to be version 2.2.14-4 and PHP is a bit old version 5.2.5 from Nov 8, 2007 so that is not the way for you to upgrade.
However, I have noticed that your conclusion was to switch to Geoserver. Follow the situation, perhaps you can switch back one day but once you have configured Geoserver and built all the SLD styles it may feel a bit heavy.
-Jukka Rahkonen-
EVANS, JAMES wrote:
> Hi,
> I'm running the dev version of MS4W with Mapcache. Our security scans are
> pointing to Apache and PHP that came with MS4W as vulnerabilities. Our system
> admin tried updating the Apache, but this caused problems with
> mod_mapcache.dll. Has anyone had any luck upgrading the Apache and PHP
> that came with MS4W without breaking things? Also, is there a good document
> describing how to deploy the latest Mapserver/Mapcache on a widows server?
> James
