[mapserver-users] How to deal with (visible) CONNECTION information in .MAP file for WMS purposes
Siki Zoltan
siki at agt.bme.hu
Mon Jan 6 02:03:47 PST 2014
Hi Stefan,
you should hide your map file using a wrapper script on the server side.
See http://mapserver.org/cgi/wrapper.html
You can find some other methods at
http://mapserver.org/ogc/wms_server.html
look for "Changing the Online Resource URL"
Regards,
Zoltan
On Mon, 6 Jan 2014, Stefan Schwarzer wrote:
> Hi there,
> I am wondering how to deal with the CONNECTION information in the .MAP which is used for WMS requests. As the .MAP file must be visible and is readable, the CONNECTION information for my database is readable too.
> # Layers definition ---------------------
> LAYER
> NAME wilderness_areas_po
> METADATA
> 'wcs_label' 'Wilderness Areas'
> 'wcs_rangeset_name' 'test'
> 'wcs_rangeset_label' 'test label'
> END
> TYPE RASTER
> STATUS OFF
> DATA wilderness_areas_po
> CONNECTIONTYPE postgis
> CONNECTION 'user=my_username password=my_password dbname=my_database'
> PROJECTION
> 'init=epsg:4326'
> END
> END
> Either I would then need to create a very simple user for that case which really only can read the data, or I should hide the file in a directory which is not readable by a webuser. But I guess that Mapserver wouldn't like that.
> What are your recommendations?
> Thanks for any hints.
> Stefan
> mapserver-users at lists.osgeo.org
