[mapserver-users] non spatial MSSQL data in a Layer JOIN
Daniel Morissette
dmorissette at mapgears.com
Wed Jan 8 08:23:13 PST 2014
On 14-01-08 11:04 AM, KenHeer1 wrote:
> I have attribute data in a MS SQL database that I want to join in a Mapserver
> layer to data I have in a shapefile, but I cannot find anything that says
> yes you can or no you cannot. Really trying to get away from having to
> maintain this data in two places. The data in MSSQL is not spatial data. I
> found lots of posts on trying to get spatial data out of MSSQL but not what
> I needed. Closest result found was using ODBC connection but I couldn't find
> anything recent or specific examples.
> Is this possible and if so, can you point me to some docs on it?
You may be able to do it using OGR SQL syntax to join the two data
sources. Have a look at the JOIN in
http://www.gdal.org/ogr/ogr_sql.html#ogr_sql_joins
I didn't test with a MS SQL data source specifically to verify if it is
possible to open a MS SQL table without geometry using OGR, hopefully
that's supported. You'll find more info on the OGR syntax to connect to
MS SQL at:
http://www.gdal.org/ogr/drv_mssqlspatial.html
and here:
http://mapserver.org/input/vector/mssql.html
and finally I would advise testing the creation of your connection
string with "ogrinfo" before you try to add it to your mapfile layer.
That will save you lots of headaches.
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
