[mapserver-users] Point between 2 tiles disappearing
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Mon Jan 20 12:41:39 PST 2014
MapServer expands the search extent slightly based on feature definitions (e.g. marker size, etc...) so that partial features are captured and rendered. That should take care of a case like this. What are you using to do the tiling (i.e. mapcache, tilecache, mode=tile)?
Steve
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Geo-6 [support at geo6.be]
Sent: Monday, January 20, 2014 4:13 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Point between 2 tiles disappearing
Hello,
I forgot to say that Leaflet access to MapServer via WMS.
Here is a copy of the MAP file :
MAP
NAME "SEVESO"
STATUS ON
SIZE 500 500
EXTENT -500000 -500000 500000 500000
IMAGECOLOR 255 255 255
SYMBOLSET "C:/Program Files/Apache Software Foundation/Apache2.4/cgi-bin/mapserv_6_4/ms/symbols.txt"
FONTSET "C:/Program Files/Apache Software Foundation/Apache2.4/cgi-bin/mapserv_6_4/ms/fonts.txt"
PROJ_LIB "C:/Program Files/Apache Software Foundation/Apache2.4/cgi-bin/mapserv_6_4/proj/SHARE/"
PROJECTION
"init=epsg:31370"
END
WEB
IMAGEPATH "C:/Temp/"
IMAGEURL "/Temp/"
METADATA
"wms_title" "Seveso"
"wms_enable_request" "*"
"wms_srs" "EPSG:31370"
"wms_feature_info_mime_type" "text/plain"
END
END
LEGEND
STATUS ON
LABEL
TYPE truetype
FONT verdana
SIZE 8
COLOR 80 80 80
END
END
LAYER
NAME "SevesoSites"
STATUS ON
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "C:/Seveso.tab"
TOLERANCE 10
TOLERANCEUNITS PIXELS
DUMP TRUE
TEMPLATE "dummy.html"
METADATA
"wms_include_items" "all"
END
CLASS
NAME "Seuil haut / Hoge drempel"
EXPRESSION ([Type] = 2)
STYLE
SYMBOL "square"
COLOR 255 0 0
SIZE 8
END
END
CLASS
NAME "Seuil bas / Lage drempel"
EXPRESSION ([Type] = 1)
STYLE
SYMBOL "square"
COLOR 255 128 0
SIZE 6
END
END
END #LAYER
END #MAP
Jonathan Beliën
Geo-6
De : Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
Envoyé : vendredi 17 janvier 2014 00:28
À : Geo-6; mapserver-users at lists.osgeo.org
Cc : ms4w-users at lists.maptools.org
Objet : RE: [mapserver-users] Point between 2 tiles disappearing
What’s the layer definition look like?
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Geo-6
Sent: Thursday, January 16, 2014 11:06 AM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Cc: ms4w-users at lists.maptools.org<mailto:ms4w-users at lists.maptools.org>
Subject: [mapserver-users] Point between 2 tiles disappearing
Hi everyone,
I use MS4W (see below for more information on my version of MapServer) with Leaflet.
The projection system I use is EPSG:31370 (see below for proj4 definition).
Sometimes, at certain zoom level, when a point is between 2 tiles, the point is not shown.
Here are some screenshots :
Resolution = 10
Resolution = 5
Resolution = 2
Resolution = 1
You can see at resolution = 1 that the symbol is “cut”.
How can I fix this ?
Thanks a lot for your help and sorry for my English.
MS4W:
MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=SVGCAIRO SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE]
EPSG:31370:
+proj=lcc +lat_1=51.16666723333333 +lat_2=49.8333339 +lat_0=90 +lon_0=4.367486666666666 +x_0=150000.013 +y_0=5400088.438 +ellps=intl +towgs84=-106.869,52.2978,-103.724,0.3366,-0.457,1.8422,-1.2747 +units=m +no_defs
Jonathan Beliën
Geo-6
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140120/e7b53e95/attachment-0001.html>
