[mapserver-users] Mapserver WMS time support with Oracle
D. Nappo
domenico.nappo at gmail.com
Tue Jan 21 00:34:11 PST 2014
Many thanks!
It helped: the default date format in our system is DD-Mon-RR and I found
it out with SELECT * FROM nls_database_parameters WHERE parameter LIKE
'%DATE%'
2014/1/20 Umberto Nicoletti <umberto.nicoletti at gmail.com>
> On Mon, Jan 20, 2014 at 2:44 PM, D. Nappo <domenico.nappo at gmail.com>wrote:
>> Hi there,
>> I couldn't figure out how to solve this. I have a layer so configured:
>> LAYER
>> NAME "layer"
>> TYPE point
>> CONNECTION "conn_string...."
>> CONNECTIONTYPE ORACLESPATIAL
>> TEMPLATE "templates/hotspot_template.html"
>> DATA "SHAPE FROM (SELECT POINT as SHAPE, ACQ_DATE, ACQ_TIME,
>> SATELLITE, CONFIDENCE, VERSION, BRIGHT_T31, FRP FROM
>> gwsprd.HOT_SPOTS_MODIS) using unique OGR_FID"
>> METADATA
>> "wms_title" "WMS test"
>> "wms_srs" "EPSG:4326"
>> "wms_extent" "-180 -90 180 90"
>> "wms_timeextent" "2000-01-01/2020-12-31"
>> "wms_timeitem" "acq_date"
>> "wms_timedefault" "2014-01-01"
>> "wms_timeformat" "YYYY-MM-DD"
> Try with this:
> "wms_timeformat" "DD-MM-YY"
> it is the default format Oracle expects when converting a string to a date
> and no format has been explicitly provided.
> Hth,
> Umberto
>> "wms_enable_request" "*"
>> END
>> CLASS
>> SYMBOL 'circle'
>> SIZE 2
>> COLOR 255 0 0
>> END
>> END
>> Now, the date column in the oracle table is the acq_date field.
>> The problem is that Mapserver translates that with a wrong oracle query
>> (which it works in postgreslq, I guess):
>> SELECT OGR_FID,rownum, SHAPE FROM
>> (SELECT OGR_FID, POINT as SHAPE, ACQ_DATE, ACQ_TIME, SATELLITE,
>> CONFIDENCE, VERSION, BRIGHT_T31, FRP FROM gwsprd.HOT_SPOTS_MODIS)
>> WHERE acq_date = '2014-01-16'
>> The query above uses a wrong filter and it gives the error:
>> ORA-01861: literal does not match format string
>> How can I tell to Mapserver to use a correct query??? Or do I missing
>> anyhting???
>> Something like:
>> WHERE acq_date = to_date('2014-01-16','YYYY-MM-DD')
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140121/53f8b610/attachment.html>
