[mapserver-users] Mapserver WMS time support with Oracle
D. Nappo
domenico.nappo at gmail.com
Tue Jan 21 06:18:03 PST 2014
...but unfortunately MapServer wms time support doesn't include that format:
http://mapserver.org/it/ogc/wms_time.html
2014/1/21 D. Nappo <domenico.nappo at gmail.com>
> Many thanks!
> It helped: the default date format in our system is DD-Mon-RR and I found
> it out with SELECT * FROM nls_database_parameters WHERE parameter LIKE
> '%DATE%'
> 2014/1/20 Umberto Nicoletti <umberto.nicoletti at gmail.com>
>> On Mon, Jan 20, 2014 at 2:44 PM, D. Nappo <domenico.nappo at gmail.com>wrote:
>>> Hi there,
>>> I couldn't figure out how to solve this. I have a layer so configured:
>>> LAYER
>>> NAME "layer"
>>> TYPE point
>>> CONNECTION "conn_string...."
>>> CONNECTIONTYPE ORACLESPATIAL
>>> TEMPLATE "templates/hotspot_template.html"
>>> DATA "SHAPE FROM (SELECT POINT as SHAPE, ACQ_DATE, ACQ_TIME,
>>> SATELLITE, CONFIDENCE, VERSION, BRIGHT_T31, FRP FROM
>>> gwsprd.HOT_SPOTS_MODIS) using unique OGR_FID"
>>> METADATA
>>> "wms_title" "WMS test"
>>> "wms_srs" "EPSG:4326"
>>> "wms_extent" "-180 -90 180 90"
>>> "wms_timeextent" "2000-01-01/2020-12-31"
>>> "wms_timeitem" "acq_date"
>>> "wms_timedefault" "2014-01-01"
>>> "wms_timeformat" "YYYY-MM-DD"
>> Try with this:
>> "wms_timeformat" "DD-MM-YY"
>> it is the default format Oracle expects when converting a string to a
>> date and no format has been explicitly provided.
>> Hth,
>> Umberto
>>> "wms_enable_request" "*"
>>> END
>>> CLASS
>>> SYMBOL 'circle'
>>> SIZE 2
>>> COLOR 255 0 0
>>> END
>>> END
>>> Now, the date column in the oracle table is the acq_date field.
>>> The problem is that Mapserver translates that with a wrong oracle query
>>> (which it works in postgreslq, I guess):
>>> SELECT OGR_FID,rownum, SHAPE FROM
>>> (SELECT OGR_FID, POINT as SHAPE, ACQ_DATE, ACQ_TIME, SATELLITE,
>>> CONFIDENCE, VERSION, BRIGHT_T31, FRP FROM gwsprd.HOT_SPOTS_MODIS)
>>> WHERE acq_date = '2014-01-16'
>>> The query above uses a wrong filter and it gives the error:
>>> ORA-01861: literal does not match format string
>>> How can I tell to Mapserver to use a correct query??? Or do I missing
>>> anyhting???
>>> Something like:
>>> WHERE acq_date = to_date('2014-01-16','YYYY-MM-DD')
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140121/aee2612e/attachment-0001.html>
