[mapserver-users] One table with multiple GeometryColumns
Jiří Kadlec jirikadlec2 at gmail.com
Mon Jan 27 05:17:12 PST 2014
Hi Jukka,
Yes you are right. "wms_srs" "EPSG:4326 EPSG:3067 EPSG:3857" in the
metadata block is where I need to list the supported WMS layer projections.
So in my case, I will have The  http://mapserver.org/ogc/wms_server.html
is what I was looking for. I'll rely on MapServer to reproject my layers
in-the-fly.
On Mon, Jan 27, 2014 at 3:00 PM, Rahkonen Jukka (Tike) <
jukka.rahkonen at mmmtike.fi> wrote:
>  Hi,
> So I guess that you have all the thousands of our Finnish lakes in your
> database and you have reprojected the native 3067 geometries into 4326 and
> 3857 as new columns? This is unnecessary work because Mapserver can
> reproject in-the-fly to other projections. All you need is to give the list
> of supported projections in the metadata block either on MAP or LAYER level.
> "wms_srs" " EPSG:4326  EPSG:3857 EPSG:3067"
> This and much more is well documented in
> The other folks who answered you believed that you have some lakes in
> EPSG:3067 and others in EPSG:4326 of EPSG:3857. Forget what they wrote, I
> do not believe that your case is such complicated.
> Thomas: I am sure that deep inside you knew that wms_srs can be given also
> in the LAYER metadata and thus all layers do not need to advertise the same
> list of supported projections.
> -Jukka Rahkonen-
> Jirí Kadlec wrote:
> Dear mapserver forum,
> In my PostGIS database I have a table 'lakes' with 3 geometry columns:
> the_geom4326, the_geom3857, the_geom3067
> My goal is to make my 'lakes' layer available in the 3 different
> projections: (EPSG:4326, EPSG:3857, EPSG:3067)
> Is this possible in MapServer?
> (then only way I managed so far is to serve the table as 3 different
> layers, first layer in EPSG:4326, second layer in EPSG:3857, third layer in
> EPSG:3067)
> Thanks a lot for help,
> Jiří Kadlec
> Research Assistant
> Aalto university
> Lahti, Finland
Jiří Kadlec
Research Assistant
Aalto university
Lahti, Finland
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140127/01015f1d/attachment.html>
