[mapserver-users] Can QUERY mode process XY as map/data coordinates instead of pixel XY?
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Mon Jan 27 09:28:25 PST 2014
Hi Eduardo: It's not real clear what you're trying accomplish, but I can say that imgext and img.x/.y can only take pixel coordinates. Is the problem that in your  template you can't reference the map coordinates of the click? If so, the [mapx] and [mapy] tags expose that info.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Eduardo Kanegae
Sent: Monday, January 27, 2014 11:11 AM
To: List (MapServer Users)
Subject: [mapserver-users] Can QUERY mode process XY as map/data coordinates instead of pixel XY?
hi,
I'm running MapServer 6.4.0 under Linux and I need to render an output query map (hilighting matched feature) using an URL like this:
* IMPORTANT: this 2nd query map is being rendered after a 1st query mode - it's embed into layer's template.
http://myserver/cgi-bin/mapserv?MAP=../mymap.map&MODE=query&LAYERS=all&QFORMAT=AGG8&MAP_SIZE=440+440&IMGEXT=[shpext_esc
expand=75]&QLAYER=[cl]&IMG.X=220&IMG.Y=220
BUT, I do not want to inform IMG.X and IMG.Y because this works only if I select a simple a flat line. If I choose a "curved line" (not simple flat line), XY will fall OUTSIDE the line and then my simulated "click into center" (220, 220) fails.
Then, I wanted to know if is there a way to pass img.x and img.y as map coordinates, not pixel coordinates.
thanks in advance.
Eduardo Patto Kanegae
http://www.webmapit.com | @webmapit
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
