[mapserver-users] Help with expression
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Tue Jan 28 06:14:05 PST 2014
Hmmm... If you make a request against the WFS server outside MapServer what does the result look like? Ideally you'd have the WFS server do the filtering and avoid sending extra features over the wire.
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Chrishelring [christianhelring at gmail.com]
Sent: Tuesday, January 28, 2014 3:42 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Help with expression
Thats right. :) Below is the full section from the map-file.
layer
  name 'lokalplaner-udarbejdelse'
  status off
  type polygon
  connectiontype WFS
  connection 'http://geoservice.plansystem.dk/wfs?'
  metadata
 "wfs_version" "1.0.0"
"wfs_request_method" "GET"
"wfs_typename" "lokalplan"
  end
  class
    expression ('[status]' = 'K' AND [komnr] = 175 AND [datoforsl] = 0 AND
[datovedt] = 0 AND [datoaflyst] = 0)
    style
      width 3
      outlinecolor 0 0 0
    end
    name 'Lokalplaner under udarbejdelse'
    label
      type TRUETYPE
      font arial
      color 0 0 0
      outlinecolor 255 255 255
      size 8
      position cc
      offset 5 0
      antialias true
    end
  end
  labelitem 'plannavn'
  group 'theme-lokalplaner_udarbejdelse'
  projection
 "init=EPSG:25832"
  end
end
As you can see, and maybe I should have mentioned that is that the layer is
a WFS. Could that be the issue?
Christian
View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-with-expression-tp5100327p5100398.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
