[mapserver-users] Variable substitution in CONNECTION string on cascading WMS?
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Jan 28 07:26:56 PST 2014
Those need to be removed, there's a validation section a little later in that same document that takes precedence. I'll create a documentation ticket.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen Jukka (Tike)
Sent: Tuesday, January 28, 2014 8:35 AM
To: Mapserver Users (mapserver-users at lists.osgeo.org)
Subject: Re: [mapserver-users] Variable substitution in CONNECTION string on cascading WMS?
That was my impression too but paragraph "Parameters Supported" in http://mapserver.org/cgi/runsub.html emphasizes just these two:
*LAYER: DATA (must validate against DATAPATTERN
*OUTPUTFORMAT: FORMATOPTION: FILENAME (must have a MAP VALIDATION pattern)
-Jukka-
Lime, Steve D wrote:
> Validation is required for substitution to work... -Steve
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-
> bounces at lists.osgeo.org] on behalf of Rahkonen Jukka (Tike)
> [jukka.rahkonen at mmmtike.fi]
> Sent: Monday, January 27, 2014 11:15 PM
> on cascading WMS?
> Hi,
> Documentation says that CONNECTION in one place where it is supported
> so have a try http://mapserver.org/cgi/runsub.html. Validation may be
> needed or not, I am not sure how to interpret the documentation but
> you will notice it soon. Take a habit to use DEBUG 5 and read your errorfile while experimenting.
> By the way, you do not read polygons from the remote WMS, you read rasters.
> Thus TYPE RASTER.
> -Jukka Rahkonen-
> Robert Sanson wrote:
> > Hi
> > Is it possible to have variable substitution within the CONNECTION
> > string for
> CONNECTIONTYPE WMS?
> > Here is a layer section from my mapfile:
> > LAYER
> > NAME farm
> > GROUP "CRS"
> > TYPE POLYGON
> > STATUS ON
> > CONNECTION "http://remoteserver/cgi-bin/mywms.exe?farmid=%farmid%"
> > CONNECTIONTYPE WMS
> > METADATA
> > "wms_srs" "EPSG:2193"
> > "wms_name" "farm"
> > "wms_server_version" "1.1.1"
> > "wms_format" "image/png"
> > "wms_exceptions_format" "application/vnd.ogc.se_xml"
> > END
> > END
> > I am wanting to hit my cascading Mapserver WMS and pass it a farmid
> > value
> which should then be passed through to the other WMS server for processing.
> > Many thanks,
> > Robert Sanson
> This email and any attachments are confidential and intended solely
> for the addressee(s). If you are not the intended recipient, please
> notify us immediately and then delete this email from your system.
> This message has been scanned for Malware and Viruses by Websense
> Hosted Security.
> www.websense.com
