[mapserver-users] Variable substitution in CONNECTION string on cascading WMS?
Robert Sanson Robert.Sanson at asurequality.com
Wed Jan 29 11:26:00 PST 2014
Hi
Perfect - things work now. Here is my layer:
LAYER
  NAME farm
  GROUP "CRS"
  TYPE RASTER
  STATUS ON
  CONNECTION "http://remoteserver/cgi-bin/mywms.exe?farmid=%farmid%"
  CONNECTIONTYPE WMS
  VALIDATION
   'farmid'         '^[A-Z]{2}[0-9]{5}$'
  END
  METADATA
   "wms_srs"             "EPSG:2193"
   "wms_name"            "farm"
   "wms_server_version"  "1.1.1"
   "wms_format"          "image/png"
   "wms_exceptions_format" "application/vnd.ogc.se_xml"
  END
 END
Regards,
Robert
>>> "Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us> 29/01/2014 4:26 a.m. >>>
Those need to be removed, there's a validation section a little later in that same document that takes precedence. I'll create a documentation ticket.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen Jukka (Tike)
Sent: Tuesday, January 28, 2014 8:35 AM
To: Mapserver Users (mapserver-users at lists.osgeo.org)
Subject: Re: [mapserver-users] Variable substitution in CONNECTION string on cascading WMS?
That was my impression too but paragraph "Parameters Supported" in http://mapserver.org/cgi/runsub.html  emphasizes just these two:
*LAYER: DATA (must validate against DATAPATTERN
*OUTPUTFORMAT: FORMATOPTION: FILENAME (must have a MAP VALIDATION pattern)
-Jukka-
Lime, Steve D wrote:
> Validation is required for substitution to work... -Steve
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-
> bounces at lists.osgeo.org] on behalf of Rahkonen Jukka  (Tike)
> [jukka.rahkonen at mmmtike.fi]
> Sent: Monday, January 27, 2014 11:15 PM
> on      cascading WMS?
> Hi,
> Documentation says that CONNECTION in one place where it is supported
> so have a try http://mapserver.org/cgi/runsub.html. Validation may be
> needed or not, I am not sure how to interpret the documentation but
> you will notice it soon. Take a habit to use DEBUG 5 and read your errorfile while experimenting.
> By the way, you do not read polygons from the remote WMS, you read rasters.
> Thus TYPE RASTER.
> -Jukka Rahkonen-
> Robert Sanson wrote:
> > Hi
> > Is it possible to have variable substitution within the CONNECTION
> > string for
> CONNECTIONTYPE WMS?
> > Here is a layer section from my mapfile:
> > LAYER
> >   NAME farm
> >  GROUP "CRS"
> >   TYPE POLYGON
> >  STATUS ON
> >   CONNECTIONTYPE WMS
> >   METADATA
> >    "wms_name"            "farm"
> >   END
> >  END
> > I am wanting to hit my cascading Mapserver WMS and pass it a farmid
> > value
> which should then be passed through to the other WMS server for processing.
> > Many thanks,
> > Robert Sanson
> This email and any attachments are confidential and intended solely
> for the addressee(s). If you are not the intended recipient, please
> notify us immediately and then delete this email from your system.
> This message has been scanned for Malware and Viruses by Websense
> Hosted Security.
> www.websense.com
