[mapserver-users] Installing mapserver 6.4 with cmake - custom library paths
Jiří Kadlec
jirikadlec2 at gmail.com
Wed Jan 29 00:09:10 PST 2014
After a couple of failed trials with cmake, I resorted to installing the
older version MapServer 6.2.2.
I've described my installation steps on the Webfaction webhosting account
here:
https://community.webfaction.com/questions/15234/web-map-service-wms-installation
I think that more examples on compiling mapserver with cmake (similar to
http://mapserver.org/installation/unix.html) would really help people like
me who are not Linux and cmake experts.
Cheers,
Jiri
On Tue, Jan 28, 2014 at 3:09 PM, Jiří Kadlec <jirikadlec2 at gmail.com> wrote:
> I tried to understand the documentation
> https://github.com/mapserver/mapserver/blob/rel-6-4-1/INSTALL.CMAKE#L174
> But I'm still stuck.
> Here are the steps that I did:
> wget http://download.osgeo.org/mapserver/mapserver-6.4.1.tar.gz
> tar -xf mapserver-6.4.1.tar.gz
> cd mapserver-6.4.1
> mkdir build
> cd build
> cmake -DCMAKE_PREFIX_PATH=$HOME:$HOME/bin:$HOME/lib:$HOME/bin/gdal-config
> -DCMAKE_INSTALL_PREFIX=$HOME -DWITH_WCS=1 -DWITH_WFS=1 -DWITH_PROJ=1
> -DWITH_POSTGIS=1 -DWITH_FCGI=0 -DWITH_FRIBIDI=0 ..
> $HOME/bin/gdal-config --version is 1.10.1
> $HOME/bin/proj is version 4.8.0
> But for some reason, cmake still wants to use the old "system" version of
> gdal and proj libraries because it shows the following output:
> -- * Summary of configured options for this build
> -- * Mandatory components
> -- * png: /usr/lib64/libpng.so
> -- * jpeg: /usr/lib64/libjpeg.so
> -- * freetype: /usr/lib64/libfreetype.so
> -- * Optional components
> -- * GDAL: /usr/lib/libgdal.so
> -- * OGR: /usr/lib/libgdal.so
> -- * GD: disabled
> -- * GIF: /home/keskari/lib/libgif.so
> -- * MYSQL: disabled
> -- * FRIBIDI: disabled
> -- * CAIRO: /usr/lib64/libcairo.so
> -- * SVGCAIRO: disabled
> -- * RSVG: disabled
> -- * CURL: disabled
> -- * PROJ: /usr/lib64/libproj.so
> -- * LIBXML2: /usr/lib64/libxml2.so
> -- * POSTGIS: /usr/pgsql-9.1/lib/libpq.so
> -- * GEOS: /usr/lib64/libgeos_c.so
> -- * FastCGI: disabled
> -- * Oracle Spatial: disabled
> -- * SDE: disabled
> -- * Exempi XMP: disabled
> -- * Optional features
> -- * WMS SERVER: ENABLED
> -- * WFS SERVER: ENABLED
> -- * WCS SERVER: ENABLED
> -- * SOS SERVER: disabled
> -- * WMS CLIENT: disabled
> -- * WFS CLIENT: disabled
> -- * ICONV: ENABLED
> -- * Thread-safety support: disabled
> -- * KML output: disabled
> -- * Z+M point coordinate support: disabled
> -- * XML Mapfile support: disabled
> -- * Mapscripts
> -- * Python: disabled
> -- * PHP: disabled
> -- * PERL: disabled
> -- * RUBY: disabled
> -- * JAVA: disabled
> -- * C#: disabled
> -- * Apache Module (Experimental): disabled
> -- Will install files to /home/keskari
> -- Will install libraries to /home/keskari/lib64
> -- Configuring done
> Also, I'm getting a lot of warnings like:
> CMake Warning at CMakeLists.txt:263 (add_executable):
> Cannot generate a safe runtime search path for target legend because
> files
> in some directories may conflict with libraries in implicit directories:
> runtime library [libproj.so.0] in /usr/lib64 may be hidden by files in:
> /home/keskari/lib
> runtime library [libgdal.so.1] in /usr/lib may be hidden by files in:
> /home/keskari/lib
> runtime library [libxml2.so.2] in /usr/lib64 may be hidden by files in:
> /home/keskari/lib
> Some of these libraries may not be found correctly.
> Why is CMake unable to find the correct GDAL and PROJ libraries? Can you
> see anything wrong I'm doing in my cmake command?
> Thanks,
> Jiri
> On Tue, Jan 28, 2014 at 12:18 PM, Thomas Bonfort <thomas.bonfort at gmail.com
>> On 28/01/2014 11:03, Jiří Kadlec wrote:
>> > I'm trying to install the latest version of mapserver (6.4) on my Linux
>> > webhosting account (webfaction.com). The default libraries such as
>> GDAL,
>> > PROJ and Libxml2 on the WebFaction's server are quite old, so I
>> installed
>> > the latest versions of gdal, proj and libxml2 in my $HOME/lib directory.
>> > I noticed that I should use the cmake tool to build mapserver. I need
>> some
>> > help with cmake: How do I tell cmake to use the proj, gdal and libxml2
>> > libraries from my $HOME/lib folder instead of the default locations?
>> > Here is the content of my $HOME/lib folder:
>> > drwxr-xr-x 2 keskari keskari 4096 Jan 25 19:45 gdalplugins
>> > -rw-r--r-- 1 keskari keskari 136728250 Jan 25 19:45 libgdal.a
>> > -rwxr-xr-x 1 keskari keskari 1054 Jan 25 19:45 libgdal.la
>> > lrwxrwxrwx 1 keskari keskari 17 Jan 25 19:45 libgdal.so ->
>> > libgdal.so.1.17.1
>> > lrwxrwxrwx 1 keskari keskari 17 Jan 25 19:45 libgdal.so.1 ->
>> > libgdal.so.1.17.1
>> > -rwxr-xr-x 1 keskari keskari 58424319 Jan 25 19:45 libgdal.so.1.17.1
>> > -rw-r--r-- 1 keskari keskari 2442638 Jan 28 07:37 libproj.a
>> > -rwxr-xr-x 1 keskari keskari 922 Jan 28 07:37 libproj.la
>> > lrwxrwxrwx 1 keskari keskari 16 Jan 28 07:37 libproj.so ->
>> > libproj.so.0.7.0
>> > lrwxrwxrwx 1 keskari keskari 16 Jan 28 07:37 libproj.so.0 ->
>> > libproj.so.0.7.0
>> > -rwxr-xr-x 1 keskari keskari 1143691 Jan 28 07:37 libproj.so.0.7.0
>> > -rw-r--r-- 1 keskari keskari 7214544 Jan 25 19:59 libxml2.a
>> > -rwxr-xr-x 1 keskari keskari 932 Jan 25 19:59 libxml2.la
>> > lrwxrwxrwx 1 keskari keskari 16 Jan 25 19:59 libxml2.so ->
>> > libxml2.so.2.8.0
>> > lrwxrwxrwx 1 keskari keskari 16 Jan 25 19:59 libxml2.so.2 ->
>> > libxml2.so.2.8.0
>> > -rwxr-xr-x 1 keskari keskari 4237533 Jan 25 19:59 libxml2.so.2.8.0
>> > drwxrwxr-x 2 keskari keskari 4096 Jan 28 07:37 pkgconfig
>> > drwx------ 2 keskari keskari 4096 Aug 23 2012 python2.3
>> > drwx------ 2 keskari keskari 4096 Jun 26 2013 python2.4
>> > drwx------ 2 keskari keskari 4096 Aug 23 2012 python2.5
>> > drwx------ 3 keskari keskari 4096 Jan 25 19:59 python2.6
>> > drwxrwxr-x 42 keskari keskari 4096 Nov 23 07:43 python2.7
>> > -rw-r--r-- 1 keskari keskari 216 Jan 25 19:59 xml2Conf.sh
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Jiří Kadlec
> Research Assistant
> Aalto university
> Lahti, Finland
Jiří Kadlec
Research Assistant
Aalto university
Lahti, Finland
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140129/c097ce74/attachment.html>
