[mapserver-users] XML parsing error with extended Inspire WMS 1.1.1 capabilities
Julien Cigar jcigar at ulb.ac.be
Wed Jan 29 06:07:15 PST 2014
On Wed, Jan 29, 2014 at 01:59:02PM +0000, Rahkonen Jukka  (Tike) wrote:
> Hi,
> So where is the bug? In OpenJUMP, SAX, Mapserver, the configuration in Toscane, or in Inspire?
I don't know it it's related, but I had a lot of parsing problems with
SLD stylesheets .. I'll try to make a bug report as soon as I have time.
> -Jukka Rahkonen-
> Stephan Meißl wrote
> > Lähetetty: 29. tammikuuta 2014 15:48
> > Vastaanottaja: mapserver-users at lists.osgeo.org
> > Aihe: Re: [mapserver-users] XML parsing error with extended Inspire WMS 1.1.1
> > capabilities
> > Hi,
> > maybe the problem is that the inspire related elements are defined directly in the
> > capabilities document and not in the referenced DTD [1] and thus not found by
> > SAX.
> > Merging the definitions into one document and using it with libxml2 successfully
> > validates the capabilities provided in autotest.
> > cu
> > Stephan
> > [1] http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd
> > On 01/29/2014 10:47 AM, Yves Jacolin wrote:
> > > Hello,
> > > I have the same issue. It seems that namespace header are not correct
> > > (just a guess, I could be wrong).
> > > Changing wms_inspire_capabilities from "embed" to "url" make a correct
> > > GetCapabilities.
> > > I can fill an issue and add some simple mapfile if needed.
> > > Regards,
> > > Y.
> > > 2013-11-25 Rahkonen Jukka <jukka.rahkonen at mmmtike.fi
> > > <mailto:jukka.rahkonen at mmmtike.fi>>
> > >     Hi,
> > >     The SAX parser in OpenJUMP reports an error when trying to read the
> > >     GetCapabilities from Mapserver 6.5-dev based WMS service of Toscana.
> > >     The URL to use is
> > http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=
> > wm
> > > sctr&service=WMS&version=1.1.1&request=GetCapabilities
> > >     The error from the parser is:
> > >     IOException: org.xml.sax.SAXParseException: The prefix "xsi" for
> > >     attribute "xsi:type"
> > >     associated with an element type "inspire_common:MandatoryKeyword" is
> > >     not bound.
> > >     WMS 1.1.0 works OK (probably because GetCapabilities come without
> > >     Inspire stuff) as well as WMS 1.3.0.
> > >     -Jukka Rahkonen-
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
