[mapserver-users] XML parsing error with extended Inspire WMS 1.1.1 capabilities
Stephan Meißl
stephan at meissl.name
Wed Jan 29 06:59:01 PST 2014
On 01/29/2014 02:59 PM, Rahkonen Jukka (Tike) wrote:
> Hi,
> So where is the bug? In OpenJUMP, SAX, Mapserver, the configuration in Toscane, or in Inspire?
If my suspicion is true then SAX would be needed to be extended to also
use the element definitions included directly in the capabilities
document. I guess there would also be a work around in OpenJUMP possible
as I did in libxml2.
cu
Stephan
> -Jukka Rahkonen-
> Stephan Meißl wrote
>> Lähetetty: 29. tammikuuta 2014 15:48
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: Re: [mapserver-users] XML parsing error with extended Inspire WMS 1.1.1
>> capabilities
>> Hi,
>> maybe the problem is that the inspire related elements are defined directly in the
>> capabilities document and not in the referenced DTD [1] and thus not found by
>> SAX.
>> Merging the definitions into one document and using it with libxml2 successfully
>> validates the capabilities provided in autotest.
>> cu
>> Stephan
>> [1] http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd
>> On 01/29/2014 10:47 AM, Yves Jacolin wrote:
>>> Hello,
>>> I have the same issue. It seems that namespace header are not correct
>>> (just a guess, I could be wrong).
>>> Changing wms_inspire_capabilities from "embed" to "url" make a correct
>>> GetCapabilities.
>>> I can fill an issue and add some simple mapfile if needed.
>>> Regards,
>>> Y.
>>> 2013-11-25 Rahkonen Jukka <jukka.rahkonen at mmmtike.fi
>>> <mailto:jukka.rahkonen at mmmtike.fi>>
>>> Hi,
>>> The SAX parser in OpenJUMP reports an error when trying to read the
>>> GetCapabilities from Mapserver 6.5-dev based WMS service of Toscana.
>>> The URL to use is
>> http://www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=
>> wm
>>> sctr&service=WMS&version=1.1.1&request=GetCapabilities
>>> The error from the parser is:
>>> IOException: org.xml.sax.SAXParseException: The prefix "xsi" for
>>> attribute "xsi:type"
>>> associated with an element type "inspire_common:MandatoryKeyword" is
>>> not bound.
>>> WMS 1.1.0 works OK (probably because GetCapabilities come without
>>> Inspire stuff) as well as WMS 1.3.0.
>>> -Jukka Rahkonen-
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
