[mapserver-users] XML parsing error with extended Inspire WMS 1.1.1 capabilities
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Fri Jan 31 05:10:59 PST 2014
> I get this error: Namespace prefix xsi for type on MandatoryKeyword
> is not defined
You're right. The problem using DTD is that namespace declarations are done
using FIXED attributes. Therefore the DTD part
<!ATTLIST inspire_common:MandatoryKeyword
xmlns:inspire_common CDATA #FIXED "http://inspire.ec.europa.eu/schemas/common/1.0"
Should be:
xmlns:xsi CDATA #FIXED "http://www.w3.org/2001/XMLSchemainstance"
Because for element inspire_common:Keyword the xsi:type attribute is declared
it should probably also be done for the inspire_common:MandatoryKeyword.
So I would consider this being an incomplete document type definition. Fixing this should be simple.
HTH
