[mapserver-users] Can't get mapcache/mapserver to properly display a map.
TrolliPolli
aondra at lgsinnovations.com
Mon Jun 30 09:53:22 PDT 2014
Thank you for the response!
In that case, how do I go about actually opening my map?
I've tried using the url:
http://localhost/mapcache/?map=/gisDirectory/osm-outlined,google,usshields.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=borders1&STYLES=&SRS=EPSG:4326%20&BBOX=-20000000,-20000000,20000000,20000000&WIDTH=800&HEIGHT=800&FORMAT=image/png
to open my map "osm-outlined,google,usshields.map" (note that I generated
this using the tutorial found HERE
<http://trac.osgeo.org/mapserver/wiki/RenderingOsmDataUbuntu> ) which has
many layers, one of which being named borders1.
This simply says "The webpage is not available" and in my error log file I
find:
received wms request with invalid layer "borders1"
I've tried using layers other than borders1, but I always get this error.
I can post the whole map file if this would help, but it is rather large as
I generated it for a large OSM map.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-t-get-mapcache-mapserver-to-properly-display-a-map-tp5148847p5148852.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
