[mapserver-users] Can't get mapcache/mapserver to properly display a map.
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Mon Jun 30 10:00:10 PDT 2014
Your URL is wrong. Read this also http://www.mapserver.org/mapcache/install.html and follow the examples. If you find that documantation is poor or wrong, suggest how to improve it.
-Jukka Rahkonen-
________________________________________
TrolliPolli wrote:
Thank you for the response!
In that case, how do I go about actually opening my map?
I've tried using the url:
http://localhost/mapcache/?map=/gisDirectory/osm-outlined,google,usshields.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=borders1&STYLES=&SRS=EPSG:4326%20&BBOX=-20000000,-20000000,20000000,20000000&WIDTH=800&HEIGHT=800&FORMAT=image/png
to open my map "osm-outlined,google,usshields.map" (note that I generated
this using the tutorial found HERE
<http://trac.osgeo.org/mapserver/wiki/RenderingOsmDataUbuntu> ) which has
many layers, one of which being named borders1.
This simply says "The webpage is not available" and in my error log file I
find:
received wms request with invalid layer "borders1"
I've tried using layers other than borders1, but I always get this error.
I can post the whole map file if this would help, but it is rather large as
I generated it for a large OSM map.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-t-get-mapcache-mapserver-to-properly-display-a-map-tp5148847p5148852.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
