[mapserver-users] CLUSTER_GET_ALL_SHAPES gives bad query output
yeryry yeryry at gmail.com
Sat Oct 4 07:01:15 PDT 2014
It seems that the problem described in
http://osgeo-org.1560.x6.nabble.com/CLUSTER-and-GetFeatureInfo-td4227414.html
is still present. When retrieving the details for a cluster, the
cluster-related attributes are set only for the last member of the
cluster, and normal attributes for that member aren't sent. The normal
attributes for all members should be sent, and I would think the
cluster-related ones should be set for each member, not just the last.
