[mapserver-users] CLUSTER_GET_ALL_SHAPES gives bad query output
Tamas Szekeres
szekerest at gmail.com
Sat Oct 4 09:49:05 PDT 2014
I'm not sure which MapServer version we are talking about. The recent
versions should provide all attributes.
When using CLUSTER_GET_ALL_SHAPES you can use the Cluster_BaseFID attribute
to identify the shapes which belong to the same cluster and Cluster_BaseFID
is in fact the feature ID of the main shape of the cluster.
Tamas
2014-10-04 16:01 GMT+02:00 yeryry <yeryry at gmail.com>:
> It seems that the problem described in
> http://osgeo-org.1560.x6.nabble.com/CLUSTER-and-GetFeatureInfo-td4227414.html
> is still present. When retrieving the details for a cluster, the
> cluster-related attributes are set only for the last member of the
> cluster, and normal attributes for that member aren't sent. The normal
> attributes for all members should be sent, and I would think the
> cluster-related ones should be set for each member, not just the last.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141004/65830526/attachment.html>
