[mapserver-users] CLUSTER_GET_ALL_SHAPES gives bad query output
Tamas Szekeres
szekerest at gmail.com
Sat Oct 4 13:22:01 PDT 2014
That might be true. The aggregated attributes are set only for the main
shape of the cluster. Feel free to submit a ticket for the issue, I hope
that this can be implemented with no performance impact.
Colons have been replaced with underscores which are more xml friendly, but
we might also require to modify the aggregate values (Min:, Max:, Sum:,
Count:) this way.
Best regards,
Tamas
2014-10-04 22:03 GMT+02:00 yeryry <yeryry at gmail.com>:
> Ah, thanks. I had been using 6.4.1, with WMS GetFeatureInfo.
> https://github.com/mapserver/mapserver/commit/898ab8b944a6340b5a8742fe12d3aee6ca236e88
> fixed my main problem. Using a newer version, the attributes for the
> last item are again present.
> The FeatureCount (Now Cluster_FeatureCount rather than
> Cluster:FeatureCount it seems?) is still only present for the last
> item in the cluster though. The new Cluster_BaseFID is present for
> each item.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141004/c1899db6/attachment.html>
