[mapserver-users] Mapcache Question
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Oct 10 05:16:34 PDT 2014
On 10/10/2014 3:23 AM, Vladimir wrote:
> Hello ALL!
> I dig into MapCache now and my modest comprehension is:
> 1) MapCache uses Mapserv for seeding tiles or more exactly -
> sends WMS request to Mapserv for getting a map:
> <source>....</source> section in a mapcache.xml file
> 2) Ol uses MapCache for rendering that tiles or more exactly -
> sends WMS(or other) request to MapCache:
> new ol.layer.Tile({
> source: new ol.source.TileWMS(({
> url: 'myhost/mapcache/?',
> params: {'LAYERS': 'mytileset'},
> serverType: 'mapserver'
> where
> /mapcache/ is path to a mapcache.xml(aliased through Apache),
> 'mytileset' is <tileset name="mytileset"> section in a mapcache.xml file
> 3)The Seeding and the rendering needs other configuration of
> mapcache.xml file(it is needs clarification).
> 4)The seeding may be through:
> mapcache_seed -c mapcache.xml -t mytileset-g mygrid
> or
> during a certain map area is requested by client (it is needs
> clarification).
Yes, this seems correct. I will not that you CAN NOT use mapcache_seed
AND web requests TOGETHER as they do not use compatible locking
mechanisms. So either use mapcache_seed before you deploy or use the web
requests to dynamically seed the cache. You can use mapcache_seed to do
a partial pre seeding (like rectangles around major cities) then change
over to web request which will generate tiles as needed in the remaining
areas.
-Steve W
> Thanks for any correction.
> Best regards.
> Wed, 1 Oct 2014 19:33:12 -0400 от Travis Kirstine
> <tkirstine at firstbasesolutions.com>:
> Tim,
> MapCache Is simply a tiling server. It will take images from a
> source and store them in a cache. These tiles are exposed as
> services to clients - WMTS, WMS, TMS etc... MapServer on the other
> hand will read source data (GIS files / database) and render images
> based on rules defined in the mapfile. These images are used as the
> source for MapCache.
> On Wed, Oct 1, 2014 at 5:58 PM, Tim Nasman <tnasman at rollingleaf.com
> <//e.mail.ru/compose/?mailto=mailto%3atnasman at rollingleaf.com>> wrote:
> I have read through the Mapcache documentation but I feel like I
> am missing some basic elements to how it works.
> I am using Mapcache to display a mbtile that I have created.
> Now from what I understand, my mapcache .xml will list out the
> parameters of the mbtile and then I add a layer within my
> mapfile referencing the .xml which I should then be able to to
> use as WMTS using openlayers. I just haven't grasped how
> mapcache and mapserv work together so any clarification would be
> helpful. Thanks for your time.
> Timothy Nasman
> Data Analyst | Programmer
> Rolling Leaf Inc.
> [V] : 910.274.1436
> [E] : tnasman at rollingleaf.com
> <//e.mail.ru/compose/?mailto=mailto%3ajochs at rollingleaf.com>
> mapserver-users at lists.osgeo.org
> <//e.mail.ru/compose/?mailto=mailto%3amapserver%2dusers at lists.osgeo.org>
> FBS Logo
> *Travis Kirstine*, Web Development Supervisor
> *t *905‑477‑3600/ x /301 | *m *905‑534‑4798 |
> tkirstine at firstbasesolution.com
> <//e.mail.ru/compose/?mailto=mailto%3atkirstine at firstbasesolution.com>
> *First Base Solutions Inc.*
> 140 Renfrew Drive, Suite 100 | Markham | Ontario | L3R 6B3
> *t* 905‑477‑3600 | *f* 905‑477‑0892 | www.firstbasesolutions.com
> <http://www.firstbasesolutions.com>
> </compose?To=mapserver%2dusers at lists.osgeo.org>
> Владимир
