[mapserver-users] installing scribeui on Ubuntu 14.04
Richard Greenwood
richard.greenwood at gmail.com
Mon Oct 13 18:14:33 PDT 2014
In requirements.txt I changed fixture from 1.6 to 1.5 and got it to build,
but not sure of possible ramifications.
On Mon, Oct 13, 2014 at 9:41 AM, Richard Greenwood <
richard.greenwood at gmail.com> wrote:
> Following the instructions at https://github.com/mapgears/scribeui
> when I did 'sudo make' I got the error:
> http://simple.crate.io/ uses an insecure transport scheme (http).
> Consider using https if simple.crate.io has it available
> Could not find a version that satisfies the requirement fixture==1.6
> (from -r requirements.txt (line 14)) (from versions: 0.9.1, 0.9.2, 0.9,
> 1.0.0, 1.0.1, 1.0.2, 1.1.0, 1.1.1, 1.1.2, 1.3.1, 1.3, 1.4, 1.5)
> Some externally hosted files were ignored (use --allow-external to
> allow).
> No distributions matching the version for fixture==1.6 (from -r
> Storing debug log for failure in /home/rich/.pip/pip.log
> make: *** [dep_requirements] Error 1
> Any suggestions?
> Thanks,
> Rich
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141013/2a155317/attachment.html>
