[mapserver-users] installing scribeui on Ubuntu 14.04
Richard Greenwood
richard.greenwood at gmail.com
Mon Oct 13 08:41:38 PDT 2014
Following the instructions at https://github.com/mapgears/scribeui
when I did 'sudo make' I got the error:
http://simple.crate.io/ uses an insecure transport scheme (http). Consider
using https if simple.crate.io has it available
Could not find a version that satisfies the requirement fixture==1.6
(from -r requirements.txt (line 14)) (from versions: 0.9.1, 0.9.2, 0.9,
1.0.0, 1.0.1, 1.0.2, 1.1.0, 1.1.1, 1.1.2, 1.3.1, 1.3, 1.4, 1.5)
Some externally hosted files were ignored (use --allow-external to allow).
No distributions matching the version for fixture==1.6 (from -r
Storing debug log for failure in /home/rich/.pip/pip.log
make: *** [dep_requirements] Error 1
Any suggestions?
Thanks,
Rich
Richard W. Greenwood, PLS
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141013/03e2e3e0/attachment.html>
