[mapserver-users] STYLEITEM AUTO and LABEL ENCODING can't exist simultaneously??
Eva Jelínková evka.jelinkova at gmail.com
Wed Oct 22 01:57:18 PDT 2014
I am using MapServer 6.4.1 and I also encountered the problem with encoding
while using STYLEITEM AUTO.
There is my mapfile and DGN file in an attachment. This mapfile works well,
because I defined LABEL there (I can! what an advantage compared to
Chinese...), but when I leave CLASS empty and set STYLEITEM AUTO, special
characters are not displaying. In this small case I can use LABEL encoding
and I can display data correctly, but if I have different DGN file with
many labels in it and in many styles, it is really unpleasant to style them
all just because of encoding...
I would really appreciate if there is possibility to define encoding in
STYLEITEM AUTO mode.
Thank you,
Eva Jelinkova
P.S.: EPSG:5514 is:
<5514> +proj=krovak +lat_0=49.5 +lon_0=24.83333333333333
+alpha=30.28813972222222 +k=0.9999 +x_0=0 +y_0=0 +ellps=bessel
+pm=greenwich +units=m +towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56
+no_defs <>
2014-10-13 8:54 GMT+02:00 Rahkonen Jukka (Tike) <jukka.rahkonen at mmmtike.fi>:
> Hi,
> It seems that you have done a good work by studying the situation yourself
> and it looks like combination “styleitem auto” and “encoding GB18030” does
> not work in your environment. However, it is unlikely that you will get any
> better answer that this one I am writing because you are using version
> 5.2.1 which was released 2008-12-08.  There can’t be many users worldwide
> who are using that old version, Chinase character set, and data from
> MapInfo TAB.
> I suggest you to update to version 6.5-dev or at least 6.4.1 and repeat
> your test. If it still fails, prepare a test package with a small sample of
> MapInfo data and a minimal but complete mapfile so other users and
> developers can reproduce the issue.
> -Jukka Rahkonen-
> TENGDA wrote:
> Hi All,
> Is there any method that I can both set 'STYLEITEM AUTO', and also set
> ENCODING GB18030?  NOTE: my mapserv is V5.2.1.
> [PROBLEM]:
> I am now using mapinfo tab files as my map data.
> Labels in the mapinfo files are in Chinese. In order to support styles
> within mapinfo, I use 'STYLEITEM AUTO'.
> Then style are displayed well, however, Chinese characters
> are not displayed properly.
> [PROBLEM DESCRIPTION]:
> • Mapserver version: 5.2.1.
> MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF
>  OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICO
> NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUP
> PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR
>  INPUT=GDAL INPUT=SHAPEFILE
> • ogrinfo of tab file:
> OGRFeature(2000_BJ10):4
>   blank (String) =
>   Style = LABEL(t:"育",a:0.000000,s:1.380000g,c:#000000,p:1,f:"")
>   POINT (1017054046.578231 612967797.60216415)
> [CONFUSING]:
> • When I use STYLEITEM AUTO, I can't set 'ENCODING GB18030' for LABEL.
> • If not using STYLEITEM AUTO, I can't set LABELITEM, because the chinese
> character is within Style=LABEL(t:"Chinese character"....).
> Method I also tried includes:
> • Change mapfile encoding from ANSI to UTF-8
> • Change MIF/MID encoding from ANSI to UTF-8, or even to BIG5.
> So, is there any method that I can both set 'STYLEITEM AUTO', and also set
> [MORE INFORMATION]:
> I also have another mapinfo tab file, whose data is like this:
> ENAME2000: String (50.0)
> OGRFeature(省界):1
>   NAME (String) = 北京市
>   AREA (Real) =             1.733
>   PERIMETER (Real) =             8.498
>   省界_ (Real) =           9
>   省界_ID (Real) =          11
>   CODE2000 (Real) = 110000
>   ENAME2000 (String) = Beijing Municipality
>   Style =
> BRUSH(fc:#f0f0f0,bc:#ffffff,id:"mapinfo-brush-2.ogr-brush-0");PEN(w:1p
> x,c:#d0d0d0,id:"mapinfo-pen-2.ogr-pen-0")
> In this situation, I can use one layer with 'STYLEITEM AUTO' to display
> styles, and another layer with 'LABELITEM NAME' and LABEL ... END to
> display Labels, without any problem. Mapfile is as follow:
>                     LAYER
>                                           ##DATASOURCETYPE 0
>                                           NAME "test"
>                                           TYPE polygon
>                                           STATUS DEFAULT
>                                           OPACITY 100
>                                           SIZEUNITS pixels
>                                           DATA "省界"
>                                           CONNECTION
> "C:\ms4w\Apache\htdocs\mapinfo\省界.TAB"
>                                           CONNECTIONTYPE ogr
>                                           STYLEITEM "AUTO"
>                                           PROJECTION
>        AUTO
>                                           END
>                                           CLASS
>        NAME
> "Untitled class"
>                                           END
>                     END
>                     LAYER
>                                           ##DATASOURCETYPE 0
>                                           NAME "省界"
>                                           TYPE annotation
>                                           STATUS DEFAULT
>                                           OPACITY 100
>                                           SIZEUNITS pixels
>                                           DATA "省界"
>                                           CONNECTION
>                                           CONNECTIONTYPE ogr
>                                           PROJECTION
>        AUTO
>                                           END
>                                           LABELITEM "NAME"
>                                           CLASS
>        NAME
> "Untitled class"
>        LABEL
> ANGLE auto
> FONT "HEITI"
> ENCODING "GB18030"
> TYPE truetype
> PRIORITY 1
> SIZE 10
> MAXSIZE 256
> MINSIZE 4
> COLOR 255 0 0
> OUTLINECOLOR 0 255 255
> BACKGROUNDSHADOWSIZE 1 1
> POSITION cc
> ANTIALIAS FALSE
> FORCE FALSE
> PARTIALS FALSE
>        END
>                                           END
>                     END
> As you can see the difference between the two kinds of tab file,
> • one set chinese character in to LABEL(t:'') field, in which I not know
> how to both set STYLEITEM AUTO and set ENCODING to LABEL.
> • the other set Chinese character to the NAME field, in which I can set
> one layer with STYLEITEM AUTO, and another layer with LABELITEM.
> Can anyone solve the problem I described in this post?
> Waiting for your reply. Thanks very much.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141022/b890daac/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141022/b890daac/attachment-0001.zip>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141022/b890daac/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141022/b890daac/attachment-0003.png>
