[mapserver-users] Symbols in KML outout
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Thu Oct 16 01:09:22 PDT 2014
Just as a quick fix, I'd propose to drop the href node if no reasonable
value is given. Anything more elaborate can be added later on. Comments?
Peter
On 10/15/2014 11:57 AM, Peter Hopfgartner wrote:
> From http://mapserver.org/output/kml_output.html#id2, it should be
> possible to have icons for sysmbols. The pixmap of the ison should be
> referenced in the href node.
> In my output, the href ode looks like:
> <href>(null)</href>
> Is there anything I missed?
> Regards,
> Peter
Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
web : www.r3-gis.com
mail : peter.hopfgartner at r3-gis.com
phone: +39 0473 494949
fax : +39 0473 069902
ATTENZIONE! Le informazioni contenute nella presente e-mail e nei documenti eventualmente allegati sono confidenziali. La loro diffusione, distribuzione e/o riproduzione da parte di terzi, senza autorizzazione del mittente è vietata e può violare il D. Lgs. 196/2003. In caso di ricezione per errore, Vogliate immediatamente informare il mittente del messaggio e distruggere la e-mail.
ACHTUNG! Die in dieser Nachricht oder in den beigelegten Dokumenten beinhalteten Informationen sind streng vertraulich. Ihre Verbreitung und/oder ihre Wiedergabe durch Dritte ist ohne Erlaubnis des Absenders verboten und verstößt gegen das Legislativdekret 196/2003. Sollten Sie diese Mitteilung irrtümlicherweise erhalten haben, bitten wir Sie uns umgehend zu informieren und anschließend die Mitteilung zu vernichten.
WARNING! This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden and could be against the law (D. Lgs. 196/2003)
