[mapserver-users] Symbols in KML outout
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Thu Oct 16 05:56:27 PDT 2014
Never used it but it seems the KML driver creates PNG images on the fly and returns them as href. This seems to be independent of the type of symbol. So you should make sure MS is able to write those images into /tmp or $MS_TEMPPATH. The "(null)" indicates that it was unable to do so.
HTH
________________________________________
Von: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org]" im Auftrag von "Peter Hopfgartner [peter.hopfgartner at r3-gis.com]
Gesendet: Donnerstag, 16. Oktober 2014 10:09
An: mapserver-users at lists.osgeo.org
Betreff: Re: [mapserver-users] Symbols in KML outout
Just as a quick fix, I'd propose to drop the href node if no reasonable
value is given. Anything more elaborate can be added later on. Comments?
Peter
On 10/15/2014 11:57 AM, Peter Hopfgartner wrote:
> From http://mapserver.org/output/kml_output.html#id2, it should be
> possible to have icons for sysmbols. The pixmap of the ison should be
> referenced in the href node.
> In my output, the href ode looks like:
> <href>(null)</href>
> Is there anything I missed?
> Regards,
> Peter
Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
web : www.r3-gis.com
mail : peter.hopfgartner at r3-gis.com
phone: +39 0473 494949
fax : +39 0473 069902
ATTENZIONE! Le informazioni contenute nella presente e-mail e nei documenti eventualmente allegati sono confidenziali. La loro diffusione, distribuzione e/o riproduzione da parte di terzi, senza autorizzazione del mittente è vietata e può violare il D. Lgs. 196/2003. In caso di ricezione per errore, Vogliate immediatamente informare il mittente del messaggio e distruggere la e-mail.
ACHTUNG! Die in dieser Nachricht oder in den beigelegten Dokumenten beinhalteten Informationen sind streng vertraulich. Ihre Verbreitung und/oder ihre Wiedergabe durch Dritte ist ohne Erlaubnis des Absenders verboten und verstößt gegen das Legislativdekret 196/2003. Sollten Sie diese Mitteilung irrtümlicherweise erhalten haben, bitten wir Sie uns umgehend zu informieren und anschließend die Mitteilung zu vernichten.
WARNING! This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden and could be against the law (D. Lgs. 196/2003)
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
