[mapserver-users] [EXTERNAL] Re: Symbols in KML outout
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Thu Oct 16 06:16:10 PDT 2014
You also have to make sure that the IMAGEURL is a full web URL not just a
path.
Mike
On 10/16/14, 8:56 AM, "Eichner, Andreas - SID"
<Andreas.Eichner at sid.sachsen.de> wrote:
>Never used it but it seems the KML driver creates PNG images on the fly
>and returns them as href. This seems to be independent of the type of
>symbol. So you should make sure MS is able to write those images into
>/tmp or $MS_TEMPPATH. The "(null)" indicates that it was unable to do so.
>HTH
>________________________________________
>Von: mapserver-users-bounces at lists.osgeo.org
>[mapserver-users-bounces at lists.osgeo.org]" im Auftrag von
>"Peter Hopfgartner [peter.hopfgartner at r3-gis.com]
>Gesendet: Donnerstag, 16. Oktober 2014 10:09
>An: mapserver-users at lists.osgeo.org
>Betreff: Re: [mapserver-users] Symbols in KML outout
>Just as a quick fix, I'd propose to drop the href node if no reasonable
>value is given. Anything more elaborate can be added later on. Comments?
>Peter
>On 10/15/2014 11:57 AM, Peter Hopfgartner wrote:
>> From http://mapserver.org/output/kml_output.html#id2, it should be
>> possible to have icons for sysmbols. The pixmap of the ison should be
>> referenced in the href node.
>> In my output, the href ode looks like:
>> <href>(null)</href>
>> Is there anything I missed?
>> Regards,
>> Peter
>Peter Hopfgartner
>R3 GIS Srl - GmbH
>Via Johann Kravogl-Str. 2
>I-39012 Meran/Merano (BZ)
>web : www.r3-gis.com
>mail : peter.hopfgartner at r3-gis.com
>phone: +39 0473 494949
>fax : +39 0473 069902
>ATTENZIONE! Le informazioni contenute nella presente e-mail e nei
>documenti eventualmente allegati sono confidenziali. La loro diffusione,
>distribuzione e/o riproduzione da parte di terzi, senza autorizzazione
>del mittente è vietata e può violare il D. Lgs. 196/2003. In caso di
>ricezione per errore, Vogliate immediatamente informare il mittente del
>messaggio e distruggere la e-mail.
>ACHTUNG! Die in dieser Nachricht oder in den beigelegten Dokumenten
>beinhalteten Informationen sind streng vertraulich. Ihre Verbreitung
>und/oder ihre Wiedergabe durch Dritte ist ohne Erlaubnis des Absenders
>verboten und verstößt gegen das Legislativdekret 196/2003. Sollten Sie
>diese Mitteilung irrtümlicherweise erhalten haben, bitten wir Sie uns
>umgehend zu informieren und anschließend die Mitteilung zu vernichten.
>WARNING! This e-mail may contain confidential and/or privileged
>information. If you are not the intended recipient (or have received this
>e-mail in error) please notify the sender immediately and destroy this
>e-mail. Any unauthorised copying, disclosure or distribution of the
>material in this e-mail is strictly forbidden and could be against the
>law (D. Lgs. 196/2003)
>_______________________________________________
>mapserver-users mailing list
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
