[mapserver-users] WMS rendering
Francesco Palermo
palermo.frances at gmail.com
Thu Oct 16 08:04:18 PDT 2014
Hello,
I'm experimenting the use of Mapserver as WMS and I'm encountering some
problems on map rendering. I'm using a shapefile as a map source and
it's a map of points (generated by a csv using ogr2ogr - Could I use
directly csv with Mapserver? I don't know). I can't get the rendering of
this map using for example QGIS or this URL in the browser (which I hope
it's correct):
http://localhost/cgi-bin/mapserv?map=/home/francesco/shared/mapserver/wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&BBOX=9.2990,43.0105,9.4894,43.0524&WIDTH=500&HEIGHT=300&FORMAT=image/png&LAYERS=test&
This is the mapfile:
MAP
NAME "test"
STATUS ON
SIZE 500 300
IMAGETYPE PNG
EXTENT 9.2990 43.0105 9.4894 43.0524
UNITS METERS
DEBUG 5
PROJECTION
"init=epsg:4269"
END
WEB
TEMPLATE "template.html"
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
METADATA
"wms_title" "WMS Demo Server"
"wms_onlineresource" "http://localhost/cgi-bin/mapserv?"
"wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
"wms_enable_request" "*"
END
END
#IMAGECOLOR 255 255 255
TRANSPARENT ON
SHAPEPATH "oilspill/"
OUTPUTFORMAT
NAME "png"
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "GAMMA=0.75"
END
SYMBOL
NAME "square"
TYPE vector
POINTS
0 0
0 1
1 1
1 0
0 0
END
FILLED true
ANCHORPOINT 0.5 0.5
END
LAYER
NAME "test"
TYPE POINT
STATUS DEFAULT
DATA "timestep24"
DEBUG 5
SIZEUNITS meters
PROJECTION
"init=epsg:4269"
END
METADATA
"wms_title" "test"
END
CLASSITEM "weight"
CLASS
STYLE
COLOR "#1014FF"
SYMBOL "square"
SIZE 0.0019
END
END
END
END
Any suggestions? Are there any errors in the mapfile? Or am I wrong in
the procedure?
Thanks,
Francesco
