[mapserver-users] WMS rendering
Jörg Thomsen
jt at mapmedia.de
Thu Oct 16 08:22:38 PDT 2014
Hello Francesco,
no error-message, only a blank image?
What's in the error-log? The MS_ERRORFILE ist set in httpd.conf?
I think symbol is veryvery small. Try >= 1.
You can use a csv-file in MapServer via OGR :)
http://mapserver.org/input/vector/ogr.html
Jörg
Am 16.10.2014 um 17:04 schrieb Francesco Palermo:
> Hello,
> I'm experimenting the use of Mapserver as WMS and I'm encountering some
> problems on map rendering. I'm using a shapefile as a map source and
> it's a map of points (generated by a csv using ogr2ogr - Could I use
> directly csv with Mapserver? I don't know). I can't get the rendering of
> this map using for example QGIS or this URL in the browser (which I hope
> it's correct):
> http://localhost/cgi-bin/mapserv?map=/home/francesco/shared/mapserver/wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&BBOX=9.2990,43.0105,9.4894,43.0524&WIDTH=500&HEIGHT=300&FORMAT=image/png&LAYERS=test&
> This is the mapfile:
> MAP
> NAME "test"
> STATUS ON
> SIZE 500 300
> IMAGETYPE PNG
> EXTENT 9.2990 43.0105 9.4894 43.0524
> UNITS METERS
> DEBUG 5
> PROJECTION
> "init=epsg:4269"
> END
> WEB
> TEMPLATE "template.html"
> IMAGEPATH "/var/www/html/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wms_title" "WMS Demo Server"
> "wms_onlineresource" "http://localhost/cgi-bin/mapserv?"
> "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
> "wms_enable_request" "*"
> END
> END
> #IMAGECOLOR 255 255 255
> TRANSPARENT ON
> SHAPEPATH "oilspill/"
> OUTPUTFORMAT
> NAME "png"
> DRIVER AGG/PNG
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> FORMATOPTION "GAMMA=0.75"
> END
> SYMBOL
> NAME "square"
> TYPE vector
> POINTS
> 0 0
> 0 1
> 1 1
> 1 0
> 0 0
> END
> FILLED true
> ANCHORPOINT 0.5 0.5
> END
> LAYER
> NAME "test"
> TYPE POINT
> STATUS DEFAULT
> DATA "timestep24"
> DEBUG 5
> SIZEUNITS meters
> PROJECTION
> "init=epsg:4269"
> END
> METADATA
> "wms_title" "test"
> END
> CLASSITEM "weight"
> CLASS
> STYLE
> COLOR "#1014FF"
> SYMBOL "square"
> SIZE 0.0019
> END
> END
> END
> END
> Any suggestions? Are there any errors in the mapfile? Or am I wrong in
> the procedure?
> Thanks,
> Francesco
> mapserver-users at lists.osgeo.org
