[mapserver-users] WMS rendering
Håvard Tveite havard.tveite at nmbu.no
Fri Oct 17 02:03:11 PDT 2014
Hi Francesco,
Do you get any error messages?
Your map file looks a bit like the example from the WMS
Server documentation (http://mapserver.org/ogc/wms_server.html),
and that should be a good starting point.
To make it easier to find the source of your problems, I
suggest that you start with the basic example in the
WMS Server documentation and expand it gradually.
Håvard
PS: You are using SIZEUNITS meters in your test layer.  That
means that your SIZE 0.0019 symbols will be very small if
you are not operating close to a 1:1 map scale.
On 2014-10-16 17:04, Francesco Palermo wrote:
> Hello,
> I'm experimenting the use of Mapserver as WMS and I'm encountering some problems on map rendering. I'm using a shapefile as a map source and it's a map of points (generated by a csv using ogr2ogr - Could I use directly csv with Mapserver? I don't know). I can't get the rendering of this map using for example QGIS or this URL in the browser (which I hope it's correct):
> http://localhost/cgi-bin/mapserv?map=/home/francesco/shared/mapserver/wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&BBOX=9.2990,43.0105,9.4894,43.0524&WIDTH=500&HEIGHT=300&FORMAT=image/png&LAYERS=test&
> This is the mapfile:
> MAP
>      NAME "test"
>      STATUS ON
>      SIZE 500 300
>      IMAGETYPE PNG
>      EXTENT 9.2990 43.0105 9.4894 43.0524
>      UNITS METERS
>      DEBUG 5
>      PROJECTION
>             "init=epsg:4269"
>      END
>      WEB
>          TEMPLATE "template.html"
>          IMAGEPATH "/var/www/html/tmp/"
>          IMAGEURL "/tmp/"
>          METADATA
>              "wms_title"           "WMS Demo Server"
>              "wms_onlineresource" "http://localhost/cgi-bin/mapserv?"
>              "wms_srs"       "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
>              "wms_enable_request" "*"
>          END
>      END
>      #IMAGECOLOR 255 255 255
>      TRANSPARENT ON
>      SHAPEPATH "oilspill/"
>      OUTPUTFORMAT
>        NAME "png"
>        DRIVER AGG/PNG
>        MIMETYPE "image/png"
>        IMAGEMODE RGB
>        EXTENSION "png"
>        FORMATOPTION "GAMMA=0.75"
>      END
>      SYMBOL
>        NAME "square"
>        TYPE vector
>        POINTS
>          0 0
>          0 1
>          1 1
>          1 0
>          0 0
>        END
>        FILLED true
>        ANCHORPOINT 0.5 0.5
>      END
>      LAYER
>        NAME "test"
>        TYPE POINT
>        STATUS DEFAULT
>            DATA "timestep24"
>        DEBUG 5
>        SIZEUNITS meters
>        PROJECTION
>             "init=epsg:4269"
>        END
>        METADATA
>          "wms_title"    "test"
>        END
>        CLASSITEM "weight"
>        CLASS
>            STYLE
>                COLOR "#1014FF"
>                SYMBOL "square"
>                SIZE 0.0019
>            END
>        END
>      END
> END
> Any suggestions? Are there any errors in the mapfile? Or am I wrong in the procedure?
> Thanks,
> Francesco
> mapserver-users at lists.osgeo.org
Håvard Tveite
Department of Mathematical Sciences and Technology, NMBU
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.nmbu.no/imt/
