[mapserver-users] WMS rendering
Francesco Palermo palermo.frances at gmail.com
Tue Oct 21 13:10:24 PDT 2014
No, I don't get any error message.
I tried to remove UNITS on mapfile but it doesn't change anything. Then
I tried to remove SIZEUNITS from the layer and the map finally appears!
Thanks to all!
Now I'll try to overlay this map on the Google Maps ;)
Francesco
Il 17/10/2014 11:03, Håvard Tveite ha scritto:
> Hi Francesco,
> Do you get any error messages?
> Your map file looks a bit like the example from the WMS
> Server documentation (http://mapserver.org/ogc/wms_server.html),
> and that should be a good starting point.
> To make it easier to find the source of your problems, I
> suggest that you start with the basic example in the
> WMS Server documentation and expand it gradually.
> Håvard
> PS: You are using SIZEUNITS meters in your test layer.  That
> means that your SIZE 0.0019 symbols will be very small if
> you are not operating close to a 1:1 map scale.
> On 2014-10-16 17:04, Francesco Palermo wrote:
>> Hello,
>> I'm experimenting the use of Mapserver as WMS and I'm encountering
>> some problems on map rendering. I'm using a shapefile as a map source
>> and it's a map of points (generated by a csv using ogr2ogr - Could I
>> use directly csv with Mapserver? I don't know). I can't get the
>> rendering of this map using for example QGIS or this URL in the
>> browser (which I hope it's correct):
>> http://localhost/cgi-bin/mapserv?map=/home/francesco/shared/mapserver/wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&BBOX=9.2990,43.0105,9.4894,43.0524&WIDTH=500&HEIGHT=300&FORMAT=image/png&LAYERS=test&
>> This is the mapfile:
>> MAP
>>      NAME "test"
>>      STATUS ON
>>      SIZE 500 300
>>      IMAGETYPE PNG
>>      EXTENT 9.2990 43.0105 9.4894 43.0524
>>      UNITS METERS
>>      DEBUG 5
>>      PROJECTION
>>             "init=epsg:4269"
>>      END
>>      WEB
>>          TEMPLATE "template.html"
>>          IMAGEPATH "/var/www/html/tmp/"
>>          IMAGEURL "/tmp/"
>>          METADATA
>>              "wms_title"           "WMS Demo Server"
>>              "wms_onlineresource" "http://localhost/cgi-bin/mapserv?"
>>              "wms_srs"       "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
>>              "wms_enable_request" "*"
>>          END
>>      END
>>      #IMAGECOLOR 255 255 255
>>      TRANSPARENT ON
>>      SHAPEPATH "oilspill/"
>>      OUTPUTFORMAT
>>        NAME "png"
>>        DRIVER AGG/PNG
>>        MIMETYPE "image/png"
>>        IMAGEMODE RGB
>>        EXTENSION "png"
>>        FORMATOPTION "GAMMA=0.75"
>>      END
>>      SYMBOL
>>        NAME "square"
>>        TYPE vector
>>        POINTS
>>          0 0
>>          0 1
>>          1 1
>>          1 0
>>          0 0
>>        END
>>        FILLED true
>>        ANCHORPOINT 0.5 0.5
>>      END
>>      LAYER
>>        NAME "test"
>>        TYPE POINT
>>        STATUS DEFAULT
>>            DATA "timestep24"
>>        DEBUG 5
>>        SIZEUNITS meters
>>        PROJECTION
>>             "init=epsg:4269"
>>        END
>>        METADATA
>>          "wms_title"    "test"
>>        END
>>        CLASSITEM "weight"
>>        CLASS
>>            STYLE
>>                COLOR "#1014FF"
>>                SYMBOL "square"
>>                SIZE 0.0019
>>            END
>>        END
>>      END
>> END
>> Any suggestions? Are there any errors in the mapfile? Or am I wrong
>> in the procedure?
>> Thanks,
>> Francesco
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Francesco Palermo
