[mapserver-users] Trouble with last dev in the GetFeatureInfo.
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Mon Oct 20 12:20:08 PDT 2014
Hmmm... This should have still been interpreted as native SQL without adding the FILTERITEM (did that work by the way?). This is an example of a configuration that will change once 7.0 is completely ready.
Regardless, instead of using a FILTER, it would be simpler to just put the where clause in the DATA statement itself, e.g.:
DATA "geometry from (select geometry mytest.layer1 where FOGLIO like '%idtpn%') using unique gid srid=25832"
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
Sent: Sunday, October 19, 2014 11:11 AM
To: Even Rouault
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Trouble with last dev in the GetFeatureInfo.
Hi Even,
thx for precious info.
So is sufficient add the
FILTERITEM.
Thx,
A.
2014-10-19 17:37 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Le dimanche 19 octobre 2014 10:39:19, Andrea Peri a écrit :
>> Hi,
>> I upgrade to the last dev of mapserver.
>> After this, I'm having some troubles when go to do Identify on a
>> layer with a GetFeatureInfo.
>> Now I'm havig this error:
>> [Sun Oct 19 10:32:25 2014].523176 msEvalExpression(): General error
>> message. Cannot evaluate expression, no item index defined.
>> I'm using a postgis to host the layer and this is the setting:
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "host=localhost dbname=test user=test password=test
>> port=5432" DATA "geometry from mytest.layer1 using unique gid srid=25832"
>> FILTER "(FOGLIO like '%idtpn%')"
>> VALIDATION
>> 'idtpn' '^[a-zA-Z0-9\-_]+$'
>> 'default_idtpn' '%'
>> END
>> This setting work for me before, so I guess there is some change to
>> do in mapfile settings, but I don't understand what.
>> Any hints ?
> Andrea,
> I believe this is a consequence of
> http://mapserver.org/development/rfc/ms-
> rfc-91.html where FILTER without FILTERITEM is now interpreted as a
> MapServer expression in all cases, and not a SQL filter for PostGIS connections.
> Although there are following disucssions on that email. See the
> following thread :
> http://lists.osgeo.org/pipermail/mapserver-dev/2014-September/014228.h
> tml
> Even
> Spatialys - Geospatial professional services http://www.spatialys.com
Andrea Peri
qwerty àèìòù
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
