[mapserver-users] Trouble with last dev in the GetFeatureInfo.
Andrea Peri aperi2007 at gmail.com
Sun Oct 19 09:11:14 PDT 2014
Hi Even,
thx for precious info.
So is sufficient add the
FILTERITEM.
Thx,
A.
2014-10-19 17:37 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Le dimanche 19 octobre 2014 10:39:19, Andrea Peri a écrit :
>> Hi,
>> I upgrade to the last dev of mapserver.
>> After this, I'm having some troubles when go to do Identify on a layer
>> with a GetFeatureInfo.
>> Now I'm havig this error:
>> [Sun Oct 19 10:32:25 2014].523176 msEvalExpression(): General error
>> message. Cannot evaluate expression, no item index defined.
>> I'm using a postgis to host the layer and this is the setting:
>>     CONNECTIONTYPE POSTGIS
>>     CONNECTION "host=localhost dbname=test user=test password=test
>> port=5432" DATA "geometry from mytest.layer1 using unique gid srid=25832"
>> FILTER "(FOGLIO like '%idtpn%')"
>>     VALIDATION
>>       'idtpn' '^[a-zA-Z0-9\-_]+$'
>>       'default_idtpn' '%'
>>     END
>> This setting work for me before, so I guess there is some change to do
>> in mapfile settings, but I don't understand what.
>> Any hints ?
> Andrea,
> I believe this is a consequence of http://mapserver.org/development/rfc/ms-
> rfc-91.html where FILTER without FILTERITEM is now interpreted as a MapServer
> expression in all cases, and not a SQL filter for PostGIS connections.
> Although there are following disucssions on that email. See the following
> thread :
> http://lists.osgeo.org/pipermail/mapserver-dev/2014-September/014228.html
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Andrea Peri
qwerty àèìòù
