[mapserver-users] Using cluster with spatialite ?
Andrea Peri
aperi2007 at gmail.com
Wed Oct 22 06:34:17 PDT 2014
I found the expalin.
Seeing the code I see the labelitem is not
Cluster:FeatureCount
but instead:
Cluster_FeatureCount
This is different from documentation.
I guess the issue is in the code.
If confirmed, I check in last dev in repository and fill an issue if necessary.
Regards,
Andrea.
2014-10-22 15:26 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I'm testing the Cluster capability of Mapserver.
> I use this configuration:
> CLUSTER
> MAXDISTANCE 20 # in pixels
> REGION "ellipse" # can be rectangle or ellipse
> #GROUP (expression) # an expression to create separate groups
> for each value
> #FILTER (expression) # a logical expression to specify the
> grouping condition
> END
> LABELITEM "Cluster:FeatureCount"
> CLASS
> NAME "ingressi grotte"
> But, I'm having an error:
> OGR Error INvalid Cluster:FeatureCount.
> The sample is take from doc so I guess the issue is somewhere else.
> I'm using spatialite, sothe my doubt is if the Cluster is working with
> spatialite.
> I guess yes because the interface is OGR, but no other explain why
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
