[mapserver-users] Using cluster with spatialite ?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Oct 22 06:56:41 PDT 2014
On 2014-10-22 10:34 AM, Andrea Peri wrote:
> Hi,
> I found the expalin.
> Seeing the code I see the labelitem is not
> Cluster:FeatureCount
> but instead:
> Cluster_FeatureCount
> This is different from documentation.
> I guess the issue is in the code.
> If confirmed, I check in last dev in repository and fill an issue if necessary.
> Regards,
> Andrea.
Careful, I believe that change was made to the unreleased 6.5-dev
version. So that is why docs have not been updated for 6.4.1
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
