[mapserver-users] Using cluster with spatialite ?
Yves Jacolin yves.jacolin at camptocamp.com
Wed Oct 22 06:59:06 PDT 2014
On Wednesday, October 22, 2014 10:56:41 Jeff McKenna wrote:
> On 2014-10-22 10:34 AM, Andrea Peri wrote:
> > Hi,
> > I found the expalin.
> > Seeing the code I see the labelitem is not
> > Cluster:FeatureCount
> > but instead:
> > Cluster_FeatureCount
> > This is different from documentation.
> > I guess the issue is in the code.
> > If confirmed, I check in last dev in repository and fill an issue if
> > necessary.
> > Regards,
> > Andrea.
> Careful, I believe that change was made to the unreleased 6.5-dev
> version.  So that is why docs have not been updated for 6.4.1
> -jeff
I confirm this, I have an old working mapfile with the Cluster:FeatureCount
parameter.
I will do some testing if I have some time.
Y.
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
