[mapserver-users] Using cluster with spatialite ?
Andrea Peri
aperi2007 at gmail.com
Wed Oct 22 07:25:21 PDT 2014
done
https://github.com/mapserver/mapserver/issues/5021
Thx,
A.
2014-10-22 15:59 GMT+02:00 Yves Jacolin <yves.jacolin at camptocamp.com>:
> On Wednesday, October 22, 2014 10:56:41 Jeff McKenna wrote:
>> On 2014-10-22 10:34 AM, Andrea Peri wrote:
>> > Hi,
>> > I found the expalin.
>> > Seeing the code I see the labelitem is not
>> > Cluster:FeatureCount
>> > but instead:
>> > Cluster_FeatureCount
>> > This is different from documentation.
>> > I guess the issue is in the code.
>> > If confirmed, I check in last dev in repository and fill an issue if
>> > necessary.
>> > Regards,
>> > Andrea.
>> Careful, I believe that change was made to the unreleased 6.5-dev
>> version. So that is why docs have not been updated for 6.4.1
>> -jeff
> I confirm this, I have an old working mapfile with the Cluster:FeatureCount
> parameter.
> I will do some testing if I have some time.
> Y.
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 021 619 10 43
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
> mapserver-users at lists.osgeo.org
Andrea Peri
qwerty àèìòù
